Thread: Driver's Window Switches
  1. Question Driver's Window Switches
    I can control all the windows except the driver's window. The door mirror switch does not work and neither do the switches illuminate when the lights are on. I have replaced the bank of 4 switches but still no joy. My question is this. Are the wires between the door and pillar the only way to access those wires? There does not seem to be a lot of room there. Where do the wires from the door go to in the car (not the door). Is there a plug at the end that i can disconnect. Is there a diagram or a "How to" re this problem? Any constructive help in this matter will be greatly appreciated.
  2. Re: Driver's Window Switches
    Dec 2007
    from whats not working check the wires between the door and car
    it is tight but its common for 1 or 2 to break
    just pull rubber boot back and check they may not seen broke but its usaly the case
  3. Re: Driver's Window Switches
    I thought I had checked the wires between the door and the car, but prompted by your response I checked again and guess what ......... a thick red/black wire had broken in two. It was well hidden, quite a way up the sleeve. I hope to fix it tomorrow and give you an update. Thanks bez101.
  4. Re: Driver's Window Switches
    Apr 2010
    London
    would you say it's best to solder the wires together?
    or just twisting back togetrher and covering with tape?
  5. Re: Driver's Window Switches
    Dec 2007
    solder if you can get in there
    if not use connectors of some kind or twist and tape
    but use a short lenght of wire if you koin old wire it will split again
  6. Re: Driver's Window Switches
    Another one to add to the list! I wonder have Audi fixed this in the newer models?
  7. Re: Driver's Window Switches
    I used an electric block to join the two wires together. I was not confident enough to solder them. It really was very tight in there. I will in the not too distant future replace the wiring loom altogether. If any one out there has performed this feat then I would love to hear from them.
    If I can do this, then believe me, any one can.
  1. Please Help Mk4 Cab window problem(s)
    By stevemac2001 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-08-2010, 03:51 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Sharan P REG drivers side window oddity
    By chally3 in forum Touran - Sharan - Caravelle
    Last Post: 17-05-2010, 01:25 PM
  4. need to replace electric window switches in drivers door handle
    By geezzr6 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2010, 05:02 PM
  5. Drivers Electric Window stuck down 98 sharan
    By gforce2k in forum Touran - Sharan - Caravelle
    Last Post: 09-03-2010, 03:16 PM
