Thread: After run water pump
  1. Exclamation After run water pump
    Apr 2007
    I have a 1986 CGT hybrid. I installed an MB engine with Lumenition EMS. After many frustrating years I am almost finished. I only need to install the afterrun water pump. Can someone please identify the relay or relays I need ? By the way, I am not installing into the original wiring scheme, giventhe CGT didn't have this pump. I will be installing it from scratch
    I have tried everywhere to identify the relay or relays but have had no luck.
    All help is most appreciated.
    Thanks,
    Miguel
    Gwent
    From what I can see on the 'magic software', the 1988 Quattro used
    part number 447 965 571A - Control unit For Water Pump, relay fan stage 1
    in relay location 6. It says MB and RR engines, (I didn't think the RR was available in 88, so the MB would be the only possibility.)
    paul20v Guest
    Quote Originally Posted by scotty33 View Post
    rr available from 88 in the home land ,if you still have not done the pump i would relay it to the fan live that would kick the pump in when ever the fan came in and a nice easy job
  1. Water pump replacement
    By felinor in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 04:17 PM
  2. Water pump symbol?????
    By Johneavsnflat5 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 04-05-2007, 10:57 AM
  3. water pump
    By garying3980 in forum Passat - Archive Topics
    Last Post: 27-02-2007, 06:34 PM
  4. Water pump..noise ???
    By redmax90 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-01-2007, 04:06 PM
