Thread: Any suggestion on how to fix these errors
Results 1 to 10 of 12
Hybrid View
  1. Any suggestion on how to fix these errors
    Well have finally got round to trying to sort my car out... i have vcds lite and ran a scan on it yesterday.. gonna start sorting issues out once and for all... any help would be appreciated.... my log is as follows
    VCDS-Lite Version: Release 1.0
    Wednesday, 13 October 2010, 23:04:00:63645
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
    Address 01: Engine Labels: Redir Fail!
    Controller: 038 906 012 AH
    Component: 1,9l R4 EDC 0000SG 2827
    Coding: 00002
    Shop #: WSC 06325
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    3 Faults Found:
    00283 - Front Left ABS Wheel Speed Sensor (G47)
    30-10 - Open or Short to Plus - Intermittent
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    35-00 - -
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    35-00 - -
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL
    Controller: 8D0 820 043 M
    Coding: 00044
    Shop #: WSC 06325
    Note: Excessive Comm Errors
    Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
    Controller: 8D0 959 655 J
    Component: Airbag Front+Seite 1001
    Coding: 01106
    Shop #: WSC 06325
    2 Faults Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
    32-10 - Resistance too High - Intermittent
    01217 - Side Airbag Igniter; Driver Side (N199)
    Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
    Controller: 8D0 920 950
    Component: KOMBI+WEGFAHRS. M73 D08
    Coding: 00440
    Shop #: WSC 00654
    Ident.-Nr. Wegfahrs.:AUZ5Z0X7264210
    Address 25: Immobilizer Labels: None
    Controller: Bit teA dre ssu
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error ocurred
    Address 35: Centr. Locks Labels: 8D0-862-257.LBL
    Controller: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 06325
    10 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch; Passenger Side or Rear
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00102
    Shop #: WSC 06325
    1 Fault Found:
    01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
    35-00 - -
    Wednesday, 13 October 2010, 23:32:49:63645
    Control Module Part Number: 8D0 820 043 M
    Component and/or Version: A4 KLIMAAUTOMAT D56
    Software Coding: 00044
    Work Shop Code: WSC 06325
    5 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    29-10 - Short to Ground - Intermittent
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to Plus
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    I am slowly going to start looking these up but any pointers would help
    thanks
    Anthony
  2. Re: Any suggestion on how to fix these errors
    Southern County Softy
    20 Post(s)
    Clear all faults, run the car for a couple of days and scan again
    A4 2.5 tdi QS (mapped)
  3. Re: Any suggestion on how to fix these errors
    May 2008
    Do you have any dashboard warning lights on at the moment?
    Any other noticeable problems with the car? Anything not working correctly?
    if not then does as Kite says, clear everything and drive it then scan it again. Some of those faults could have been from years ago!
  4. Re: Any suggestion on how to fix these errors
    I cleared all last night after scanning and will check again tomorrow, there are definitely issues with the ABS, been like this since the bad snow in the winter, just bought two new front ABS sensors for £26 with postage which I'm guessing is not bad.
    i do have two wires hanging down from the front bumper which i think is the outside temp sensor (anyone know where to get these)
    my car runs fine once started, i just got it serviced and straight away the thing now takes about 4-5 seconds to start... the only two things they changed was the oil filter and fuel filter, i got them to change the oil and filter again and still doesn't fire that easily on start-up... any ideas.. ??
    i have put another post here with my probs over the year or so
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=107558
    the car according to temp gauge does not run around 85c which i think it should it runs about 70c
    thanks for replying, i will scan again tomorrow. first time ive used VCDS so not even sure what info i can get... can it help me diagnose the start-up issues?? Not usre if a return valve or air block problem
    Ant
  5. Re: Any suggestion on how to fix these errors
    20 Post(s)
    Change the coolant temp. sensor to see if that makes the temp gauge sit at 90c.
    If not you may need to change the thermostat.
    Try operating the glow plugs 2 or 3 times to see if that inproves starting, you may have a faulty glow plug.
  6. Re: Any suggestion on how to fix these errors
    are the temp sensor and thermostat easy to change, i "believe" they are cheapish to buy. ill give the glow plug thingy a try, will vcds tell me if my glow plugs are faulty?
    Oct 2010
    Here And There
    Quote Originally Posted by netdef View Post
    Ant
    Surely if the car was ok before this, you obviously have a problem with the valve on your fuel filter or fuel line. I highly dought they changed your oil and fuel filter again to try and resolve the problem, if they did, you need a new garage. They obviously have no clue !!!!
  8. Re: Any suggestion on how to fix these errors
    Pembrokeshire
    22 Post(s)
    i would agree, a badly fitted fuel filter. take it off and check there are 2 seals on it, and that none remain from the old fuel filter, or that none are missing
  1. Questions reguarding ISO FIX
    By dave18 in forum Pushchairs, Isofix, Baby seats, etc
    Last Post: 25-08-2010, 09:44 PM
  2. 2008 Audi A3 Wing mirror cheap fix anyone?
    By cunny678 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2010, 02:15 PM
  3. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  4. How To Fix a fuel leak
    By benpicot in forum 80 - 90
    Last Post: 23-10-2009, 10:25 PM
  5. S reg1.8t (AEB) VAG-COM errors can anyone help?
    By rwswll in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-02-2008, 08:40 AM
