Thread: A4 cabin Heating/Cooling problems
  1. A4 cabin Heating/Cooling problems
    I am looking for some help with my 2002 Audi A4 1.9 Turbo Diesel (standard UK right hand drive).
    A few months ago the heater was only blowing very cold air out of the passenger side vents (driver side was fine), irrespective of whether the aircon was switched on or off. I found a post suggesting that a few taps on one of the dampers might free them, so I tried it and it seemed to work.
    What I have noticed now is that the air con doesn't seem to work anymore and neither do the temperature controls, all I seem to get out of the system is slightly warm air. What I am after is some troubleshooting/diagnostic tips, for example things like testing voltages at certain points if the aircon is switched on, etc and I would also like to know if there is any way of doing a full reset on the aircon management system?
    Any help gratefully accepted.
    Murof
  2. Re: A4 cabin Heating/Cooling problems
    Wow, not a single response, not even someone telling me to stop being lazy and search the forums
  3. Re: A4 cabin Heating/Cooling problems
    Sep 2009
    ramsgate
    Hold down the recirculating button and push either fan speed up or temp up,can't remember which one.Ity should go into diagnostic mode.Then speed up and down to relevent number then recirculate again and there are the readings and or codes.If you want to find out more you could google 'climatronic codes audi etc etc'
    1. System error
    2. Actual value feeler virtually
    3. Actual value interior feeler console
    4. Actual value outside temperature - feeler wasserkasten
    5. Actual value outside temperature - feeler bumper
    6. Actual value blowing out feeler floor space
    7. Actual value blowing out feeler man Anstroemer
    8. Display check
    9. Actual digital value acknowledging potentiometer temperature flap
    10. Target digital value temperature flap
    11. Actual digital value acknowledging potentiometer A/C flap
    12. Target digital value A/C flap
    13. Actual digital value acknowledging potentiometer Fuss/Def flap
    14. Target digital value Fuss/Def flap
    15. Actual digital value acknowledging potentiometer ram air flap
    16. Target digital value ram air flap
    17. Driving speed (km/h)
    18. Actual value of the blower tension (volt)
    19. Desired value of the blower tension (volt)
    20. Actual value of the compressor/on-board tension (volt)
    21. Number of low-voltage events
    (not volatilely)
    22. Switching status of the high pressure switch
    23. Number of high pressure events (volatile)
    24. Number of high pressure events (not volatile)
    25. A/D value kickdown switch
    26. A/D value hot light
    27. Engine speed
    28. Compressor number of revolutions
    29. Coding
    30. Software-Version
    31. Software index
    32. Potentiometer error counter temperature flap
    33. Potentiometer error counter A/C flap
    34. Potentiometer error counter Fuss/Def flap
    35. Potentiometer error counter ram air flap
    36. Temperature flap notice cold
    37. Temperature flap notice warm
    38. A/C flap notice closed
    39. A/C flap notice opened
    40. Fuss/Def flap notice Def
    41. Fuss/Def flap notice foot
    42. Ram air flap notice up
    43. Ram air flap notice too
    44. Operating cycle counter
    45. Interior temperature counted (Ninc) dig
    46. Outside temperature filtered (°C)
    47. Outside temperature not filtered (°C)
    48. ECOR
    49. Coolant temperature
    50. Service life in min
    51. Engine temperature °C
    52. Compressor switching off conditions
    53. Announcement more actively el. Exits:
    Compressor/circulating air valve/water valve
    54. Rule index
    55. Outside temperature °C
    56. Interior feeler virtually °C
    57. Interior feeler console °C
    58. Temperature wasserkasten °C
    59. Temperature bumper °C
    60. Blowing out feeler floor space °C
    61. Blowing out feeler man Anstroemer °C
    62. Sun intensity W/m-1
    63. Sun intensity filtered W/m-1
    64. Delta exhaust rise
    65. Delta A/C Klappenverschiebung
    66. Time constant/1.6 seconds
    67. Cold weather starting correction
    68. Maximum correcting variable for i and p-portion
    69. Actual value blowing out feeler foot (cnts)
    70. Desired value blowing out feeler foot (cnts)
    71. Deviation (Epsilon)
    72. Portion (+ heat/- cool)
    Hope it helps you
  4. Re: A4 cabin Heating/Cooling problems
    Quote Originally Posted by portovechios View Post
    1. System error
    8. Display check
    (not volatilely)
    27. Engine speed
    29. Coding
    31. Software index
    48. ECOR
    54. Rule index
    Hope it helps you
    Portovechios, many thanks for replying.
  1. Please Help A4 Avant Brake Light Problems
    By Stevads4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-08-2010, 02:36 PM
  2. audi a4 1.8 auto gearbox problems
    By trueplayz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2010, 03:43 PM
  3. Please Help A4 B5 Throttle body problems
    By 28ash in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2010, 10:32 AM
  4. a4 tdi engine problems
    By shuggy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2007, 10:57 AM
  5. Audi A4 1996 TDI SE 110bhp problems
    By The Sandman in forum Archive posts
    Last Post: 29-07-2006, 07:06 PM
