Thread: Mk4 tdi acceleration problem?
Results 1 to 9 of 9
  1. Mk4 tdi acceleration problem?
    Jul 2006
    I was driving home from holiday yesterday and after sitting in traffic for a while I had a problem picking up speed. I accelerated through the gears and when i went from second to third it would get to about 2000 to 2500 rpm and then there would be no drive to the wheels even though the engine would still rev, it was almost as if something was slipping.
    I eventually cured the problem by turning the engine off and restarting.
    This is a bit of a worry as I don't want a lack of speed when overtaking etc.
    Can anyone shed any light on the matter?
    May 2007
    I sounds like cluch problem. However when you said you cured the problem by turning the engine off and restarting, It sounds odd>
    Any warning lights?
    Jul 2006
    no warning lights etc, a friend has said to me could it be to do with the ngine management system?
    I'm not sure.
    May 2007
    it could be a fuel problem, what i mean is that your engine can run and rev with a small amount, but if there is only a small amount of fuel getting into the cylinders there will no power. when you turn the engine off it could reset your fuel system, just a suggestion
    Apr 2007
    Repulik Of Mancunia
    May be worth popping it into a reptuable garage to do a Fault Code scan on it. That'll bring up a list of errors if any, which could identify the problem.
    '99 Golf GT-TDI
    MUFC - One Love
    Good Rep Always Appreciated.
    Feb 2007
    Norfolk
    hey all ,could also have something to do with mass air flow meter,have it checked as i have experienced this too,the air flow meter being the problem
    simon
    Jul 2006
    Is there any way of checking it other than going to vw?
    Jul 2006
    If i was to change the maf should I stick with a bosch replacement or are there any other makes to use? Apart from cheap ones?
    Apr 2007
    Cambs
    Pierburg, they seem to be the best replacment.
    Jim Morrison - "Expose yourself to your deepest fear, after that fear has no power, and the fear of freedom shrinks and vanishes. You are free."
  1. gti acceleration problem....
    By 2000gti in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-04-2007, 08:18 PM
  2. Mk3 Golf Tdi (1996) acceleration problem
    By Octavius in forum Golf MK3 - 1993 - 1999
    Last Post: 28-03-2007, 05:50 PM
  3. Jerky Acceleration problem
    By djronw3 in forum Passat - Archive Topics
    Last Post: 14-12-2006, 01:06 AM
  4. golf mk 3 acceleration problem
    By dawn in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-05-2006, 02:49 PM
  5. internitent acceleration problem
    By andy79 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-12-2005, 05:37 PM
