Thread: Cylinder head torque value
  1. Cylinder head torque value
    '93 2 ltr. 8v. ABT engine, auto g/b.
    I've noticed a very, very slight oil leakage at the head gasket by cylinders 3 & 4. It always reappears after a run. Since this could mean taking the head off at some point I would be obliged if someone could enlighten me about the following.
    1. Are there any known pitfalls to be wary of ?
    2. What is the correct torque value to tighten the bolts to ?
    3. Should I use new head bolts ?
    4. Is a new cambelt tensioner recommended ?
    5. Why is a " pencil magnet " a recommended tool for the head refitting procedure ?
    Regards Dos.
  2. Re: Cylinder head torque value
    May 2010
    Devon England
    hi mate the torque settings are as follows
    stage 1, 40nm
    stage 2, 60nm
    stage 3, +180 degrees
    use new bolts
    if the head comes off and the belt hasnt been changed for a while it is strongly recomended to replace the belt and tensioner
    a pencil magnet is very useful if you have stripped the head, it makes refitting the valve collets easier (they hold the valve spring in place, if you need any more info post up here or pm me
  1. Cylinder Head Required for Y Reg 1.8T... Advice Please
    By PeterPolska in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2010, 04:36 PM
  2. A4 Cylinder head problem
    By billybuttons in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-01-2010, 09:51 PM
  3. 2001 A3 cylinder head bolt torque settings
    By arcangels in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-12-2009, 12:38 AM
  4. Cylinder Head Is Off - Overheating Problem - PICS inside
    By mystic.bertie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-08-2009, 03:20 AM
  5. Mark IV 1.4 Oil consumption
    By Gravesie in forum Golf MK4 - 1999 - 2004
    Last Post: 14-09-2007, 02:36 PM
