Thread: a3 quattro problems
Results 1 to 10 of 11
  1. a3 quattro problems
    Oct 2010
    kilmarnock
    hi i have just bought a a3 55 tdi quattro 140 it sometimes goes into limp mode and the emission light has come on yellow can anyone help i also want to get a vagcom maxscan will it work on this model cheers
  2. Re: a3 quattro problems
    May 2008
    You need a VAGCOM scan for fault codes to point you in the right direction to start with. Anything would just be pure guesswork I'm afraid.
  3. Re: a3 quattro problems
    Oct 2010
    kilmarnock
    hi would the vagcom maxscan 500 work on my car
  4. Re: a3 quattro problems
    May 2008
    Quote Originally Posted by hongnor23 View Post
    Never heard of it. Its nothing to do with VAGCOM though. Google shows a "maxscan gs500" - is that what your talking about? I guess that might work.
    To be fair though, it isnt VAGCOM so I dont know. VAGCOM is the most popular tool out there and that's the one thats most referenced on here.
    If whatever tool you have can read the fault code details then thats a place to start your investigation.
  5. Re: a3 quattro problems
    Oct 2010
    kilmarnock
    hi can you tell the best place to get a vagcom
  6. Re: a3 quattro problems
    May 2008
    Either Ross Tech (The VAGCOM designers) @ www.ross-tech.com over in the USA or one of the licensed distributors here in the UK. Details on the above website or Google.
  7. Re: a3 quattro problems
    Oct 2010
    kilmarnock
    cheers for the help
  8. Re: a3 quattro problems
    Oct 2010
    kilmarnock
    the usual just before a was to take the car to the garage the light went out, the code still came up 16618 overboosting he cleared the code everything seems to be ok would that be the case or is it temperary
  9. Re: a3 quattro problems
    May 2008
    You might find it'll come back again, you might get lucky and it'll run OK from now on, just see how it goes
    http://wiki.ross-tech.com/wiki/index...8/P0234/000564 this details possible causes and things to try if the code returns.
  10. Re: a3 quattro problems
    Oct 2010
    kilmarnock
    thanks very much for the help can you buy those vagcoms from ebay av seen ones on it but not sure if their the right ones
  1. A3 2ltr Diesel 170 Quattro MPG!
    By contrakid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-06-2008, 04:30 PM
  2. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. Replies: 0
    Last Post: 30-01-2008, 08:33 PM
  5. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
