Thread: Suspension rattle after replacement
  1. Suspension rattle after replacement
    Me again with this bloody suspension. I have replaced the dampers, springs, control arms, drop links and ARB bushes. Everything is back together and the car feels great.
    However, there is a rattle when I go over bumps at a low speed. It is not a knock but quieter than that.
    The control arm kit I bought came with replacement nuts and bolts. The nuts for securing the lower ball joints are just nylon lock nuts. The nuts that came off were shoudlered nuts and looked a lot more substantial. Because of this I stuck a washer under the nut. I am wondering if that nut and washer are just not putting enough tension on the joint and that is rattling. Or have I cocked up in some other way?
  2. Re: Suspension rattle after replacement
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I have a knock or rattle from the front os susspension, but I have not replaced anything for sometime. i just can't findwhere it is comming from. low speed knock as i go over a small bump. I thought it might be the top susspension mount, but have not checked it yet. I will let you know when i do.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Re: Suspension rattle after replacement
    Jul 2006
    Same thing on my 1.9tdi, try going over a bump you know causes the rattle with the brakes on slightly, if you here no noise remove and clean up your front brake pads and use copper grease during reassembly. Hope this helps
  4. Re: Suspension rattle after replacement
    Aug 2006
    i agree,it could be brake pads jingling in the caliper,we have found that on a few escorts,laguna,s and a few more cars over the years,take each front wheel off and slowly turn the brakedisc and you may see the pad move slightly,a little movement on the pads can give a knock or rattle for sure...
  5. Re: Suspension rattle after replacement
    Thanks for the replies chaps. It turns out in the end it was the top damper nut that wasn't tight enough.
    I didn't have an appropritate tool to stop the piston turning whilst I tightened the nut so I wizzed it up with an impact wrench which obviously wasn't good enough.
    You need either one of those sockets with the hole in the side or a deep offset spanner so you can get the allen wrench into the top of the piston.
    Anyway fixed nowm car runs great. Just got the rears to do at some point!
  6. Re: Suspension rattle after replacement
    Aug 2007
    Hook Hampshire
    21 Post(s)
    iwaters, can you remind me. Do you have to remove the struts to tighten this nut or can it be done in situ from the engine compartment. I may have to check mine this weekend.
  7. Re: Suspension rattle after replacement
    Struts out I'm affraid. The top nut is covered by the mounting plate.
  1. Will Koni FSD dampers fix harsh ride on A6 with factory sports suspension?
    By john528 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-12-2009, 06:51 AM
  2. Please Help Mk4 2002 GT TDi 150 - suspension arms replacement.
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2009, 11:53 PM
  3. Question Fron Suspension Rattle
    By ssmyth182 in forum A8 - S8 - V8
    Last Post: 16-07-2009, 07:04 PM
  4. Suspension replacement
    By Andy N.I in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2009, 07:58 PM
  5. Suspension replacement
    Last Post: 01-02-2008, 09:36 AM
