Thread: Door Light/Courtesy Light/Headlight On Alarm
  1. Door Light/Courtesy Light/Headlight On Alarm
    Oct 2010
    purley, uk
    I have a June 2001 Fabia. Generally pleased with the car although there have been many problems. However, I am extremely frustrated with the current "issue" - should I leave the headlights on and then open the driver's door, the alarm does not sound. Also, the red door light does not seem to work nor does (more often than not) the interior courtesy light come on when they should be activated by/on the driver's door.
    Extremely frustrating but I can't find any form of "pin" which may be sticking on the driver's door frame aperture and when I've spoken to a couple of garages, it seems this may be an electrical wiring problem. Slightly scared to take off the entire door seal in case I reposition incorrectly and then no longer have a watertight seal.
    I'm not technical but have a logical head on my shoulders so should be able to tackle most things.
    Does anyone please have any idea where I should begin in my quest to get this problem fixed? Thank you
    Oct 2010
    Here And There
    I would say if the wiring up to the door mech is ok, it will need the door mech replaced as thats where the micro switch lives. Check the wiring where your door meets the body, in the rubber or take of the panel and make sure the clip has not released from the wires and made the wires rub through from being in contact with the window. Guessing I would say mech though
  1. Please Help Alarm failure on passat 2001 2ltr
    By ST.Alban in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2009, 08:18 PM
  2. Please Help Factory Alarm stopped working
    By avata_jo in forum Golf MK2 - 1984 - 1992
    Last Post: 21-07-2009, 07:01 AM
  3. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  4. alarm triggered with driver door
    By Steve-R in forum VCDS - General Questions
    Last Post: 05-05-2008, 07:31 PM
  5. intermittent door light/headlight warning alarm
    By warrydave in forum Golf MK3 - 1993 - 1999
    Last Post: 16-03-2008, 12:31 PM
