Thread: Epu ?
  1. Epu ?
    Apr 2009
    Liverpool
    Hello people, back again for more of your invaluable knowledge.
    2000 Audi A4 avant estate 1.8 78k on the clock. Was reversing into the drive when I lost all the power from the engine.The car will only idle at 2-3k revs and nothing happens when you press the accelerator. The EPU ? light is lit on the dash, this came on when the power died.Question is what is it ?
    What does it do ? and how much am I looking at for repair. The car is only worth a grand or so and I dont want to get rid, but if its not worth it then sadly I will be parting company with my beloved.
    Hope some one can help.
    Oct 2010
    Here And There
    First thing is first. Get her plugged on to see what your fault codes are. Then repost
  3. Re: Epu ?
    Quote Originally Posted by Nijusho51 View Post
    ...The EPU ? light is lit on the dash...
    EPC - Electronic Power Control. Its the 'drive by wire' or electronic throttle. Have a look at the accelerator pedal and make sure the plug coupler to the pedal hasn't been dislodged by your foot. Maybe try unplugging and re-plugging. Check the harness is intact.
    It *may* be a problem with the throttle valve. But as the other poster suggests, it will have to go on the diagnostic.
    A new accelerator pedal assembly is the most likely to cure this.
