Thread: 2.5TDi Injector pump worth repairing?
  1. Question 2.5TDi Injector pump worth repairing?
    Apr 2009
    Ok I have a 99 2.5TDi Avant which is in fairly good condition but has now developed a fault with the injector pump i.e. won't start without some Easystart down the manifold. (SNAP ON code 00550 Faulty start valve). After a little research it seems that this is fairly common problem. It seems a rebuild is the only way to go. My question is is it worth it? I guess I'm looking at a minimum of 2 hours labour (x1 to remove & x1 to refit). Then the cost of a rebuild which people tell me is a minimum of £500. The car has near 200K on the clock, am I just throwing good money away or is it worth fixing?
    ALL COMMENTS WELCOME.....
    Audi A4 Avant 2.0 TDi 2009
  2. Re: 2.5TDi Injector pump worth repairing?
    Jan 2009
    Falmouth, UK
    Had mine fixed by dieselbob at about the same mileage, just over £500 for complete mechanical and electronic rebuild,you will get back performance you didn't know was missing. Car has 213000 miles, no intention of selling it for a long time yet
    2001 Audi A6 2.5TDI Avant quattro Sport, Celtic Tuning remap, TurboDynamics MD438 hybrid turbo, 3" decatted Longlife stainless exhaust, Bosio Race683 nozzles
    2004 Audi A4 1.9TDI Avant quattro + Superchip
    1988 Yamaha FJ1200
  3. Re: 2.5TDi Injector pump worth repairing?
    Jan 2010
    margate uk
    I had the same fault - posted elsewhere. I changed the glow plugs but no difference. I then found leaking fuel return hoses so replaced all these which was pennies and it then started on the button.
    I had the 0550 code and it was going into limp mode after start up. Try starting from cold and holding the throttle down at over 2000 revs for a couple of minutes.
    It cured my "duff" pump so it is worth a try before you spend loads of money. The codes do not mean you need a new pump.
  4. Unhappy Re: 2.5TDi Injector pump worth repairing?
    Apr 2009
    Quote Originally Posted by freddyuk View Post
    Already did this and the AA man redid it just to be sure. I even drove for miles to clear any air locks/ bubbles in the system but as soon as you turn the engine off it won't restart.
  5. Re: 2.5TDi Injector pump worth repairing?
    Jan 2010
    margate uk
    Check very carefully the filter connections. The two rear pipes are prone to leak. I cut 10mm off mine as i was getting large bubbles in the fuel line. It did clear up that leak point. Are you seeing air bubbles?? Driving mine for miles did not clear the air until i sealed all the leaky joints.
    Hopefully you will find something as it will not be obvious that air is getting in.
  1. 107k 2.5tdi no service history, buy?
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-10-2010, 10:22 PM
  2. Please Help Is it worth it?
    By lew247 in forum Octavia
    Last Post: 03-06-2010, 04:59 PM
  3. A4 2.5TDi Cabriolet - Any good???
    By nickynibbles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-01-2008, 11:57 AM
  4. Looking To Buy VagCom Is It Worth It???
    By cyberduderen in forum VCDS - General Questions
    Last Post: 15-10-2007, 09:22 PM
  5. What is my Passat worth???
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2007, 01:25 PM
