Thread: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
  1. Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Surbiton, Surrey
    Currently I have Polo but planning to buy Skoda Octavia, just seen one, it's '2002 SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate' done 160k and priced at £1500.
    Checked the mielage from all MOT certificates and looks OK.
    Considering high mielage anything particular I would look for.
    Basically need need car for family and daily commuting to work which is round trip 100 miles .
    OR should I look for lower mielage car.
    Any suggestions would be appreciated.
  2. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    May 2007
    Newark On Trent, Nottinghamshire
    For the money that is pretty much on the button but with any car mileage does kill it. The engine is pretty rock solid but look for a good service history, not just the stamps in the book but ask for receipts. If there is little / no service history then walk away.
    Check the cambelt and check the clutch for signs of wear.
    the 1900 lump is pretty bullet proof, but expect things around it to go wrong (after all it has done 160,000).
    All in all, its always best to opt for a lower mileage but if your budget dictates then you could do a lot worse.
    Best of Luck
    Bora23
    2001 Passat B5 1.9 TDI 130ps Inky Blue, 2006 Skoda Octavia 2.0 TDI 140ps Corrida Red, 2002 Audi A6 1.9 TDI 130ps Blue (Now Gone), 2002 Golf 1.9 GT TDI 130ps Jazz Blue (Now Gone),2002 Bora V5 170 PS Jazz Blue (Now Gone), 2006 Seat Leon TDI FR 170 in Black (Now Gone)
  3. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Surbiton, Surrey
    Hi mate, thank you very much for the suggestion, probably look for some low meilage octavia.
  4. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Nov 2008
    folkestone.kent
    low mileage skodas fetch good money though..... you may well need to double your first figure before you find something with half desent mileage.......................
  5. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    At 160K miles even if the engine is fine , a lot of the ancillaries start to go .Things like suspension bushes , alternators , clutches etc . You might be lucky and find a high mileage car that has been serviced on the dot and sympathetically driven but these cars are like hens' teeth. If you are doing 100 miles per day you want something with a lot less mileage. I used to do 120 miles per day and it mounts up quite quickly. Even if the car's fine you will soon find that brakes , tyres etc soon wear out doing this kind of mileage.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Nottingham
    Dual Mass Flywheel (clatter when turning engine off, uneven vibration at idle), front wishbone rear bushes (wooly steering) rear beam bushes (kcik under the bum and rear steering) turbo VNT failure (diagnostic scan/obvious driving issue with power delivery) flap motor V71 (recirculatory/fresh air function does not change over properly on heater) air con (no cold air, clutch falls off the Sanden SD7V16 pump) I could go on.
    Get a full inspection wit a diagnostic scan, if it's not too bad have it well serviced, fix the bits it needs and enjoy.
    Greg.
  7. Re: Buying SKODA OCTAVIA 1.9 TDi Elegance 5dr Diesel Estate
    Surbiton, Surrey
    Hi Greg, Thanks for useful info, I would keep these things in mind when buying one of high mielage Skoda.
  1. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  2. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  3. '06 1.9 TDi (105) Estate buying advice
    By captain_nesmo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-05-2009, 06:06 PM
  4. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
