Thread: 2001 A6 B5 2.5TDi - Sitting Low From The Front
  1. 2001 A6 C5 2.5TDi - Sitting Low From The Front
    Dec 2008
    Leicester
    Hello again.. another query, or possible issue with my Audi A6.
    It a 2001 Audi A6 C5 2.5TDi Saloon. It seems to sit pretty low at the front. The springs/shocks all appear to be doing their jobs and are not broken.
    When I spoke to my mechanic about this, he said it's common on these cars, as they have big heavy engines in the front, and tend to do this.
    What do you guys think?
    (I will try and get some photos up, but won't be until tonight/tomorrow when I get a chance to take a snap).
    Nik
  2. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Apr 2009
    Epsom Downs
    Take the cheapskate option and lower the back!
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  3. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Mar 2008
    High Wycombe
    Mine's got standard suspension, and does look quite low at the front. If you want, tell me the measurement between the tyre and the wheel arch, and I'll measure mine for you to compare.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Dec 2008
    Leicester
    Thanks Nick. Good idea. I'll take a couple of pics and get those measurements when I get home tonight..
  5. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Oct 2010
    Bristol, UK
    Hi all
    Similar problem, I think - I'm forever bottoming the front of my car on speed bumps - thank heavens for the solid under tray beneath the engine/gearbox or else I'd have done some damage before now.
    What I'm wondering is whether springs or shock absorbers fall off in efficiency and the front drops Would new shocks be worthwhile?
    I noticed when I had the car in for rear brakes that the blue rubber "doughnuts" at top and bottom of rear springs were perished and starting to break up - are there similar doughnuts on the front springs and could that be a cause?
    Regards
    John
  6. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Aug 2007
    Wicklow
    On the first A6 I bought all the bushes were pretty badly worn in a lot of the front suspension link arms. I ended up changing every arm in the front and was surprised by how much this raised the car up.
  7. Re: 2001 A6 B5 2.5TDi - Sitting Low From The Front
    Dec 2006
    Crook, County Durham
    Hi, check on the label in the boot to see if it is fitted with sports suspension, if it is then it might have had standard springs fitted at a later date. The standard springs are'nt as thick. I could only get sports springs from Audi. £150 for the pair.
  1. 2001 2.5tdi a6 avant help needed pls
    By kudos100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-08-2010, 01:20 PM
  2. How does the Quattro system work?
  3. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
  4. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
  5. New Sporting Audi A6 S Line models arrive in britain
    Last Post: 15-07-2004, 09:40 PM
