Thread: Fuse for fan heater blower?
Results 1 to 10 of 14
Hybrid View
  1. Fuse for fan heater blower?
    Sep 2010
    Hitchin, UK
    Does anyone know which fuse is the one for the fan blower.
    Or have any ideas about why mine does not work in any of the four settings 1,2,3 or 4
    I've tried the Resistor in the side of the motor and that made no difference.
    Van is a 2.5 tdi T5
    Many thanks
  2. Re: Fuse for fan heater blower?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Usually the Resistor is the usual suspect ! I take it you checked the main live into the Resistor ? Other problems are the motor itself, but the switches are usually fine.
    2 fuse panels behind cover in dash. Check card to see fuse positions. Check for a live at resistor and motor.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Fuse for fan heater blower?
    Sep 2010
    Hitchin, UK
    Checked there was live going to the motor, and resistor and there is.
    Took the motor out and connected it directly to a battery and it doesn't seem to work, so I guess I need a new fan blower motor then.
    Anyone know where I can get on at a reasonable price. The vw dealership want £198!!!!!!!!!! Eeeek...
    However, i've found one that looks like the same motor, but from a golf. Is it the same? If so it's only £38 from a breakers.
    Does anyone know of a vw transporter breakers?
    Sorry... Lots of questions I know, but i've got to get this sorted before the colder whether gets here and mists up my windscreen leaving me trying to drive using The Force...
    Oct 2010
    Here And There
    Give it a kick. You could try eddie torrens in ballymoney, northern ireland. He delivers too. Probably a little more expensive than if you get it local to your self and a real grumpy git to talk to but he will definitly have one !
  5. Re: Fuse for fan heater blower?
    Sep 2010
    Hitchin, UK
    Hi Bangor Lad,
    I gave your suggestion a go (kick it) and F**k me, when I got in the van thismorning the blower was working..... But only for about five minutes then it just stopped.... bugger! Could it be a fuse or something that wobbles when driving, meaning it works intermitantly?
  6. Re: Fuse for fan heater blower?
    Nov 2008
    20 Post(s)
    No, it`ll be the motor faulty.
    Alan.
    Oct 2010
    Here And There
    You see mission lol. Sometimes technical diagnosing just confuses things ! It means its the motor. When you move ( kick the bugger ) it makes contacts that are worn/burnt out contact until they reposition themselves.
  8. Re: Fuse for fan heater blower?
    Sep 2010
    Hitchin, UK
    Thank Bangor Lad,
    Just trying to avois spending £200 that the dealer wants for a new motor ..eeek
    And I can't seem to find one second hand.. bugger! Oh well..
    Oct 2010
    Here And There
    Did you try eddie torrens ? He is in northern ireland but does post
  10. Re: Fuse for fan heater blower?
    Margate,Kent
    Does the motor spin freely by hand ?
    If it does then its probably the carbon brushes worn - if so then you could try a domestic appliance repairer to get some that will either fit or can be adapted.
    If the motor soes not spin freely then squirt a tiny drop of WD 40 (or similer) into the bearings, run for a couple of minutes then get some oil such as engine oil & get that into the bearings (just a little - say match head sized drop).
    If nether work then the motor itself is US.
    take care & enjoy life
    Brian Considine
  1. Question Polo '02 - Cabin Heater Fuse
    By Preo in forum Polo - Derby - Lupo - Fox
    Last Post: 25-10-2009, 04:40 PM
  2. Blower not working - fuse box not as per manual?
    By oxtailsoup in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-05-2009, 03:34 PM
  3. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  4. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
  5. Alhambra blower failed and fuse melted
    By kester_holmes in forum Alhambra
    Last Post: 27-08-2007, 06:42 PM
