Thread: crankshaft back seal leak oil
  1. crankshaft back seal leak oil
    Oct 2010
    estonia
    Car of the VW Touran 2.0TDI 103kW DSG 2005, which is leaking from the engine crankshaft oil seal at the rear end. The strip has already been changed 3 times over and over again, however, the seal between the engine begins to run out of oil. Anywhere else in the engine oil does not come off. Change is the engine head cover. Can anybody give advice as to what to do.
    Oct 2010
    Here And There
    You must have blocked breathers somewhere. She will just keep blowing seals if you dont clear them.
  3. Re: crankshaft back seal leak oil
    Oct 2010
    estonia
    Only breathe is on the head cover and this is new. What opportunities have?
    Oct 2010
    Here And There
    Too much back pressure, bad and very "butchery way" out of it would be to drill small breather holes in oil cap. Might blow oil out of it still at that. Is your crankseal still leaking ? Maybe there is a groove worn into the crank itself ? No seal will repair it
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  4. Answers from an oil expert...
    Last Post: 20-01-2008, 05:30 PM
