Thread: diagnostic codes for injectors
  1. diagnostic codes for injectors
    Nov 2008
    My car stalled and wouldn't restart.
    It's at my local garage and they can't diagnose the problem, does anyone know where I can get the injectors checked out with the true diagnostic codes to see which isn't working. The gararge say the injectors are the piezo injector type but the codes they can read aren't helping and they are struggling to find someone who can check out the injectors.
    Some of the similar forum entries talk about a maf problem, what is this?
    Many thanks for any help on this.
  2. Re: diagnostic codes for injectors
    Norfolk
    Take it to a garage that know what they are doing and has VCDS.
    The codes will be.
    004160 - Supply voltage A for injectors: Circuit Malfunction
    P1040 - 006 - Short to Plus - Intermittent
    008518 - Supply voltage for Fuel Injector Group A: Open Circuit
    P2146 - 009 - Open or Short to Ground
    For a failed injector and the engine won't start. It's a simple process to find the dud one.
    B6 engines rarely give a faulty injector code. All B6 2.0 td's have piezo injectors. They cost about £500 each plus £200 or so for fitting.
    It won't be a failed MAF. That won't stop the engine running.
  3. Re: diagnostic codes for injectors
    Nov 2008
    Martin, thanks for this.
    Does anyone know of a garage in the north west (Blackpool area) that has VCDS and can be recommended?
  4. Re: diagnostic codes for injectors
    Oct 2010
    wales
    Hi Richard
    Can I ask how many miles you've done in your car?
    Mine has done this at 101k
  5. Re: diagnostic codes for injectors
    Nov 2008
    Only about 43K.
  6. Re: diagnostic codes for injectors
    Dec 2009
    14 Post(s)
    Quote Originally Posted by RichardJWilson View Post
    I would do a search on the net failing that go to the local *******s.
  1. 99 A6 Avant 4.2 - misfire but no fault codes
    By sparkyjf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-08-2010, 08:20 PM
  2. Replies: 3
    Last Post: 06-06-2009, 01:40 PM
  3. 95 Passat diagnostic codes
    By randombob1190 in forum Early Passat Forum - Pre 97
    Last Post: 13-04-2009, 07:53 AM
  4. Climate control diagnostic codes
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-04-2009, 06:33 PM
  5. caravelle automatic diagnostic codes?
    By Russellbar01 in forum Chat - Completely Off Topic
    Last Post: 20-01-2007, 02:22 AM
