Thread: passat accelerator position sensor
  1. passat accelerator position sensor
    May 2009
    Stourport UK
    Hi, I'm new to all this forum lark so bear with me.
    Passat 1.9tdi 130 engine code AWX. 54plate.
    Had this motor for 18mths and its been a gem until yesterday junction 22 of the M1 it lost all power. Jolly fine chap from the RAC diagnosticated the car to a "18047 accelerator position sensor 1/2 (G79 / G185) implausible signal". Once this was cleared the old girl got me the 70 or so miles home without a whimper. Should I replace the sensor or is it now 'fixed'. Also noticed a load of water in the driver footwell is it possible that a bit of water affected the sensor? Your thoughts please before I dare go to the local dealership.
  2. Re: passat accelerator position sensor
    Norfolk
    It's two sensors in one. Dry everything out and see how you go. If it happens again you will have to replace the throttle pedal as the sensors are part of it.
  3. Re: passat accelerator position sensor
    May 2009
    Stourport UK
    I'll try that. Thanks for the prompt reply.
  4. Re: passat accelerator position sensor
    Merseyside
    This happened to a mates car; one day he started it and it would only tick over and not rev up. A few hours later it was fine, but he had the same fault code stored as you. It was caused by blocked plenum drains, normally it floods the passenger side but it can also affect the drivers side too.
  5. Re: passat accelerator position sensor
    May 2009
    Stourport UK
    Yup, they were blocked up. I've just finished drying out the carpets both sides so i'll see how it goes. Many thanks.
  1. coolant temperature sensor G2 passat B5
    By arasl in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2010, 08:48 AM
  2. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  3. (estates/wagons) Audi A4 vs Audi A6 vs Passat
    By passat938 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-05-2009, 01:40 PM
  4. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  5. new passat engine oil & light sensor!
    By frank in forum Passat - Archive Topics
    Last Post: 04-11-2006, 10:34 PM
