Thread: Rainwater in V reg Bora footwells
  1. Rainwater in V reg Bora footwells
    Sep 2007
    For the second time in our ownership of our 1.9 TDi, following heavy rain water has appeared in all the vehicle footwells, yet doesn't seem to have wet any of the seats etc.
    The last time we had a problem, a quick clean out of the drainage ducts at the front of the sunroof did the trick. But having tried the same tactic this time, I'm not sure it's solved the problem.
    Any thoughts/suggestions how this problem might be addressed would be very welcome.
  2. Re: Rainwater in V reg Bora footwells
    Jan 2010
    nottingham endland
    check the rubber casing in the doors that covers the wiring if they are loose they let water in it happened to mine a new cost £2-3:00 at vw shop
  3. Re: Rainwater in V reg Bora footwells
    Sep 2007
    Thanks for that. I've gone back thru' a few posts on the same subject on this forum, and now have a list of possibilities.
  4. Re: Rainwater in V reg Bora footwells
    Mar 2007
    I had this on a Jetta I had many moons ago (1986 model!!) and I traced it to a missing rubber grommet somewhere in the engine bay. It was caused by water splashing up from the wheels when driving. If yours is happening when the car is standing still, then you need to look higher up, somewhere where water will travel down and reach the footwell. Basically, all cut-out holes in the bodywork should have a grommet, so if you see a hole without one, it might be the culprit.
    Andy.
  5. Re: Rainwater in V reg Bora footwells
    Sep 2007
    Thanks again. Still waiting for some heavy rain with the vehicle stationary to help with the diagnosis.
  1. Question Fitting a Rear wiper on a VW Bora 2000 reg
    By maverick_sgs in forum Bora - 1998 - 2005
    Last Post: 16-12-2009, 11:56 PM
  2. bora 2.0 sport w reg
    By lurch2006 in forum Bora - 1998 - 2005
    Last Post: 29-03-2008, 12:16 AM
  3. Which engine oil for W reg Bora 2.0se?
    By xerian in forum Bora - 1998 - 2005
    Last Post: 31-12-2007, 10:51 AM
  4. x reg bora v5 replace alternater
    By camiedon in forum Chat - Completely Off Topic
    Last Post: 13-01-2007, 02:51 PM
  5. Rainwater leak on 80 footwells
    By MattX in forum 80 - 90
    Last Post: 23-11-2006, 09:29 PM
