Thread: Brake calliper mount bolt size.....???
  1. Brake calliper mount bolt size.....???
    Hi desperatly need help,changed the rear rotors had a awful time trying to get the brake caliper mount off >< resulting in destroying 2/4 bolts.
    Can anybody tell me the thread size of them they are not M8 or M10
  2. Re: Brake calliper mount bolt size.....???
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Might be M9. VW do use some non-preferred std. screw thread sizes in critical areas ( space constraints). If you need new bolts I would order them from VW - don't try to use standard bolts.
    Skoda Octavia II SE 1.9PD TDI
  3. Re: Brake calliper mount bolt size.....???
    Jul 2008
    stoke on trent
    metric fine thread, (m8 if i remember correctly), coil on thread is half the size of a normal bolt, about £3 from audi or 20p from any fastener company
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  4. Re: Brake calliper mount bolt size.....???
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    By ordering from VAG it can be assured that the Bolt is the correct size, the correct thread pitch and the correct high tensile strength grade. Ordering bolt from a fastener stockist is fraught with danger ( brake caliper bolts shearing ?). If the recommended tightening torque for a high tensile bolt is applied to a lower grade strength bolt then it will likely shear.
    In my experience Fastener stockists do not stock fine thread bolts as they are non-standard sizes.
  5. Re: Brake calliper mount bolt size.....???
    Jul 2008
    stoke on trent
    never had any problems using fastener companies, as long as you take the bolt with you they will match it
    metric fine is common in industrial use where vibration/space is an issue
    90 eunos roadster
  6. Re: Brake calliper mount bolt size.....???
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I agree that the larger Fastener suppliers may have the correct bolt in the correct length but there's not many of these companies about these days and to waste time and fuel to pick up a few bolts to save a couple of pounds seems to me to be a bit pointless. Also I doubt you could get a high tensile M8 fine thread bolt for 20 pence. Also most specialist suppliers will only sell a minm. quantity - normally at least 50 in this size. Unless you've got a specialist fastener supplier close to your doorstep who will sell in very small quantities, I would stick with the VAG parts assuming they are within reasonable travelling distance.
  7. Re: Brake calliper mount bolt size.....???
    Hi guys ty for all ur advice and help, contacted a vw dealer got the bolts. If anybody has the same problem the part number is : N90688901
  1. Wheels - this might be helpful
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 14-12-2009, 02:15 PM
  2. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. Polo brake caliper bolt seized
    By trevh in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 12:23 PM
