Thread: overcome the deadlock on the rear doors
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
  1. Re: overcome the deadlock on the rear doors
    #31
    Nov 2014
    Magyarország
    Quote Originally Posted by caldirun View Post
    The only time you need to drill is when the door is closed!
    Ok. Thank you for your help I will try it
  2. Re: overcome the deadlock on the rear doors
    #32
    Jun 2007
    West Yorkshire, UK
    hi. i've had this problem with my 2002 passat saloon. The rear passenger side door is not opening from front or back. I've checked the wiring that goes into the door and there is no sign of corrosion or breaking. I've tried tapping underneath the door handle hard whilst pressing the open button on the drivers door. I have removed the inside panel. The window is attached to the inside panel. I can see the lock. Tried tapping it with a long screw driver but not opening. Can i not add voltage to the lock mechanism to open it? Horrible job to do. Anybody with any good ideas who have done this before please share. I don't fancy putting a hole in the door but will have to if nothing else works. Or i might try smashing the lock in from inside and hope that it opens up. Will need a replacement though was hoping that the lock might be repairable.
    Can't get MOT without sorting it out.
  3. Re: overcome the deadlock on the rear doors
    #33
    Oct 2007
    Could be corrosion problems on the A post plug and socket bracket, water runs into this from the leaking pollen filter housing then creeps through the wiring loom
    corroding joints all the way to the CCM. Pull up the carpet in the passenger footwell and check for green gundge in the plugs. If found cut and join the wires around the bracket.
  4. Re: overcome the deadlock on the rear doors
    #34
    Nov 2006
    Follow this, it's brilliant and WILL work. 2003 Passat Door won't unlock or open.pdf
  5. Re: overcome the deadlock on the rear doors
    #35
    Jun 2007
    West Yorkshire, UK
    right i got it working again. I got a screwdriver and placed it directly onto the lock and then got a hammer and hammered it moderately hard a few times whilst somebody was pressing the unlock button on the drivers door with the engine started to give it most voltage. after about a minute of doing it, managed to unlock.
    After it worked i sprayed the lock with wd40. Now it opens and closes 90% of time and the deadlock seems to have been messed up on that lock which is brilliant because if it fails to unlock then you can open door from inside handle.
    The window is a complete pain to remove (don't bother) otherwise i would have removed the whole lock and greased it.
    Thanks for all the help.
  6. Re: overcome the deadlock on the rear doors
    #36
    Dec 2007
    8 Post(s)
    It may still be best to replace lock unit in case the next time it locks permanently.
    Oops I only managed to open previous post now,hope all works out well.
  7. Re: overcome the deadlock on the rear doors
    #37
    Nov 2014
    Oxford
    I used this procedure last week. It worked a treat. With a slightly different way. The hole you will drill will not put you inline with the screw!! I drilled a small hole roughly in line where the screw head is. I then looked inside with a torch to see how far away I was. I then drilled at an angle to get the head of the screw off. It fell off, I could then open the door. 2 minute after that
  8. Re: overcome the deadlock on the rear doors
    #38
    Sep 2015
    Belfast
    Hello guys. Lot's of great information here! Rear OS deadlocked several months ago (01 Passat) and today I managed to unlock it with engine on and thumping. I also disconnected the pillar harness to prevent it from deadlocking again but it also means that the electric window won’t work. Is there a way to disable the lock while keeping the electric windows working and not having to remove the inner skin?
    I am kind of afraid to take everything apart, mess with the window, etc. A few articles suggest taping the window and fully removing the inner skin (in order to replace the lock). However, this one door-lock-assembly-module-removal-handle-removal-mk4-vw | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum says that you don’t need to mess with the window, you can pull the inner skin just enough to remove the lock module (but it’s about the front door). Can the rear lock module be replaced without fully removing the inner skin and without messing with the window, etc.? Thanks.
  9. Re: overcome the deadlock on the rear doors
    #39
    Nov 2014
    Oxford
    Quote Originally Posted by Antanas26 View Post
    Might be possible but won't be easy! The window only takes a couple of seconds to pop out really! Instead of pulling the grommet push. I used a punch and pushed it through. It basically fell out. Putting back in was even easier.
  10. Re: overcome the deadlock on the rear doors
    #40
    135 Post(s)
    2038 Post(s)
    The door not opening isn't normally anything to do with the deadlocking, the can jam just by closing the door. Once you have it open, do not close it again until you have fitted a new lock unit. This comes away from the door with the window carrier unit, do not disconnect the black plastic bracket by pushing through the black plugs or it makes your life harder.
  1. Audi steps up the pace with even more extreme 560ps r8 gt
    Last Post: 05-06-2010, 07:24 PM
  2. Rear Doors
    By Borab0y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2009, 09:59 PM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. A6 Stereo problem/question. please help!!!
    By djneils98 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-03-2007, 01:22 PM
  5. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
