hello mate welcome to the site, VW ownership and PD engine ownership, now as for oil changes if you are doing it yourself BUY the oil from a VW dealer so you get the right stuff, also IMHO the longlife service plan is a bad idea, i change the oil and filter on mine every 9/10,000 miles without fail, due to the fact it will help lookafter the engine, some people will disagree on this point but i think most of the problems the PD engine has is down to the oil being changed after 20,000 miles so i do mine at 10, to try and help it last,
Cambelt, some say 60,000 some will say 80,000, i always recommend replacement every 60,000 miles or 5 yrs and when its changed fit the complete kit and a water pump, i ALWAYS fit genuine kits
There is more but this is a biggie THAT you need to do, have a look around your battery, they have a massive problem in that the drain is under the battery and it gets blocked with crap, water collects and raises and then leaks into the car under the carpet, your CCM (comfort control modual) and auto box ECU is under the carpet so it is a good idea to make sure the drain is clear on a regular basis, if you use the search button and type in passat battery drain you will find 100s of threads covering this
one last thing always use genuine filters, oil, air, fuel and pollen, they may cost afew quid more but its worth it for piece of mind
hope this helps mate, enjoy your new car bud
