Thread: Audi A4 losing power
  1. Audi A4 losing power
    Sep 2010
    Ireland
    Hi there, I was recommended by a friend to post here. I have a 2004 A4 1.6. A few months back the engine management light came on. After starting up, it goes ok until it reaches max temperature. Then there is an immediate loss of power and very sluggish response. If I stop the car and go to start again, it takes at least 10 mins (or until the engine cools) to do so. It has also cut out while waiting at traffic lights. Brought it to the garage, but nothing showed up on VAG-COM. The mechanic changed 2 sensors and it went ok for a few days, but started giving trouble again last week. Anyone have any ideas what could be wrong? Thanks.
  2. Re: Audi A4 losing power
    It could be the lambda sensors which are faulty. When the car is first started the ECU ignores the values from the lamda sensors until the car reaches operating temperature. I would have expected these to throw a fault code if they are not operating properly.
    Other than that could be a fuel pressure problem, possibly a problem with the fuel pump.
    Without any error codes it is difficult to diagnoise. If the engine management light came on, there must have been a DTC in the system, did the garage tell you what they are?
  3. Re: Audi A4 losing power
    Ireland
    Ya, agree with above. If the engine managenent light was on then there should be a falut code of some type.
    What 2 sensors did he change and why?
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  1. The efficiency standard – the audi a8 hybrid
    Last Post: 02-03-2010, 07:58 PM
  2. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  3. World Debut For The All New Audi A3 Cabriolet
  4. Audi Cross Coupé quattro - The compact performance SUV
    Last Post: 21-04-2007, 05:41 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
