Thread: Fitting S4 headlight into 1.9 QS
  1. Fitting S4 headlight into 1.9 QS
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    My 'new' car has S4 headlights and grill fitted. Not through accident damage (I have the originals). Do all S4's have xenon dipped?
    Really tho the question is this, they don't appear to fit very well, there's a gap below the units. the std (1.9TDi) front bumper is fitted, not the S4 one. Would this expliain the difference. Also should they auto level in the S4, but manual level in the 1.9. I don't believe they level at all at the moment.
    2007 A6 2.7TDi Avant Manual S-Line
    2003 A4 B6 Avant 1.9 TDi Quattro Sport, Manual -Sold
    1999T A6 C5 Avant 2.5 Auto, 244k -Sold
    2005 STM Phoenix R1 powered, 1988 205 Gti 16v tarmac rally car . . and a few motorbikes
  2. Re: Fitting S4 headlight into 1.9 QS
    Apr 2009
    Theres an EU law that says;
    "When xenons are fitted they must have auto level"
    (or something like that)
    I'm not sure, about how much it is enforced, but i think
    it means that S4 headlights don't have a manual option.
    On the gap; there should be a small amount of up and
    down adjustment, of the whole unit, which you can
    enhance with the use a few washers on the mounting bolts.
    But it won't be much.
    Regards
    Jim
  3. Re: Fitting S4 headlight into 1.9 QS
    Mar 2009
    I'll try and get some pictures. units do seem to be fitted securely. I wonder if the lack of auto levelling means that they're stuck pointing too far down as a safety feature and the bodies have been aimed up to compensate.
    Any idea how the autolevel system works. A seperate leveling ECU maybe?
  4. Re: Fitting S4 headlight into 1.9 QS
    Apr 2009
    Not sure about which ECU controls the level, but your
    right about the default going to low, in the event of
    "signal failure".
    A good spark should be able to connect your dashboard
    thumb-screw to the headlight motors via a device that
    mimics the level sensors.
    Regards
    Jim
  5. Re: Fitting S4 headlight into 1.9 QS
    Mar 2009
    yes can probably sort that out. Does the bumper need to come off to get the light units out do you know?
    Thanks for the help Jim,
    Phil
  6. Re: Fitting S4 headlight into 1.9 QS
    Apr 2009
    Theres a sticky at the top of page 1,
    see if that helps.
    Regards
    Jim
  7. Re: Fitting S4 headlight into 1.9 QS
    Dec 2007
    you can remove lights with bumper on
    theres a full retro kit for the lights at kufatec
    that will do what you need
  1. Golf Mk5 Tow Bars - Q&A - All you need to know Guide!! Advice, Tips...
    By Ben in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 03-10-2018, 01:05 AM
  2. Question S4 (B5) Vs S4 (B6)....
    By grainqey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-02-2011, 08:05 PM
  3. Question Fitting B5 S4 calipers to a B6?
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-07-2009, 02:55 PM
  4. Audi B7 S4 front brakes
    By Lee_m in forum Archive posts
    Last Post: 03-06-2007, 07:40 PM
  5. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
