Thread: Footwell lighting
  1. Footwell lighting
    Apr 2010
    Ashford, Middlesex
    Is there any easy way to fit footwell lighting to a 2007 B6?
    Also, is there a way to change the reflectors on the bottom of the door pockets into puddle lights?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  2. Re: Footwell lighting
    Norfolk
    You need the wiring and a couple of lights. You may need VCDS to program them to come on. The bits are not expensive from a dealer.
  3. Re: Footwell lighting
    Apr 2010
    Ashford, Middlesex
    Thanks Martin - do they just plug into the loom somewhere?
  4. Re: Footwell lighting
    Feb 2010
    Louth Ireland....
    I'll have a look for the part numbers for you. Have attached a screen shot of lighting bits and bobs.........
    Light Door 1KO 947 411 A
    Footwell light 6LO 947 415 A
    Bulb Door N 017 753 2
    Bulb footwell Same
    Looking for wiring now...............
    Ex Passat B6 owner......to many retrofits to mention !
  5. Re: Footwell lighting
    Feb 2010
    Louth Ireland....
    Have a look at this from another forum.............might do this myself.
    http://forums.vwvortex.com/showthrea...030&viewfull=1
    2 0 0
  6. Re: Footwell lighting
    Apr 2010
    Ashford, Middlesex
    Thanks richiemac - looks reasonably easy, so one to add to the 'to-do' list.
  7. Re: Footwell lighting
    Mar 2009
    York
    Quote Originally Posted by richiemac View Post
    Bulb footwell Same
    Another post resurrection...!
    I want to add the footwell light to both passenger and driver footwells. I'm going to get the genuine VW ones if they're not too expensive. However since I haven't got VAG com I am simply going to route the wires and splice into the interior light wires.
    Are the bulbs the standard 501s or are they something different? Would probably want to upgrade those too..
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  1. Golf mk4 water in driverside footwell and rear driverside footwell??
    By jackmutlow20 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2013, 12:35 PM
  2. A6 Avant water in footwell
    By Crabtree321 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-07-2011, 03:23 PM
  3. water in drivers side footwell
    By baj25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 04:48 PM
  4. Which LED Bulbs for footwell lights?
    By Crispy Duck in forum Golf MK6 - 2009 - 2013
    Last Post: 02-02-2010, 02:14 PM
  5. ## 2.0TDI - 05 Plate - Damp Rear footwell ##
    By RickT in forum Golf MK5 - 2004 - 2009
    Last Post: 17-02-2009, 06:42 PM
