Thread: 1.8T newbie questions
Results 1 to 10 of 14
  1. Re: 1.8T newbie questions
    Jul 2008
    stoke on trent
    regarding the central locking, heres the procedure for coding the fob
    the previous owner may have replaced pump? when you unlock with the key in door then the rest of the doors should unlock when ign is turned on if you have the correct pump fitted
    if the instructions dont work check batteries then check pump part number
    remote fob coding
    1. insert key into ignition and turn on (turn one notch do not start car) does not matter what type of key as long as it is coded to the immobiliser i.e capable of starting car
    2. insert second key (fob type) into drivers door lock and turn to lock car
    3. press unlock button on fob once (indicator may flash), wait six seconds press unlock button again, car will unlock, remove key
    4. open door and remove key from ignition, close door and press lock/unlock buttons on fob, car should now lock/unlock
    to code a second fob
    follow steps 1 + 2 using second fob to be coded to lock drivers door then press unlock button twice, wait six seconds and press unlock again, then go to step 4
    up to four keys can be coded to the pump, for third key you would press unlock 3 times, wait 6 seconds etc.... if you code key two but only press once it would replace key one as you would be storing it in position one
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  2. Re: 1.8T newbie questions
    Manchester
    hi, thanks for the reply, i tried what you said but it didnt work, i ran my fault code reader and it says this...static: key 1 adaptation limit exceded. and static: alarm horm not found.
    When i unlock the drivers door, i have to use the the door button to unlock the other doors and the same when i lock it, they dont open when i put the ignition on, also the alarm is not setting, the red led on the door is not flashing??
    i will check the pump number but how will i know if its been changed?
    Ste.
  3. Re: 1.8T newbie questions
    Jul 2008
    stoke on trent
    part number should be 8D0 862 257 E for a 2000 a4
    if youve got an adaption limit fault code then that suggests it is a remote pump so its possibly faulty
    its very common for the batteries in the siren to leak and wreck circuit board, causing it to squeal so they get disconnected
    90 eunos roadster
  1. Question A4 convertible 2005 - Newbie questions?
    By A4Blondie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-07-2010, 06:41 AM
  2. Unashamed A6 newbie questions
    By Grubscrew in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-05-2010, 12:11 PM
  3. Question b5 1.8t avant questions
    By molelos in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2010, 05:45 PM
  4. potential owner questions 1.8T quattro
    By thebloyn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 09:40 PM
  5. Newbie A4 1.8 T questions
    By Disk0 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2008, 08:30 PM
