Thread: Rear disc brake noise
  1. Rear disc brake noise
    May 2007
    Morning all,
    I have a small problem with the rear disc brakes of my A4 (96). When braking everything is fine, no pulling, no noises, etc. However, once I release the brake pedal and drive off there is a scrapping noise from the rear discs.
    I put the car up on the jack yesterday and when I spin the rear wheel by hand I get this scrapping noise. If I grab the wheel and wiggle it left/right and then spin the wheel again by hand, the noise stops and the wheel spins more freely. If I tap the brake pedal to stop the wheel, then spin the wheel again by hand the noise returns and I can tell there is some drag as the wheel stops quicker now.
    This happens on both rear wheels. Does this look like brake pads not being fitted properly? I would think that it is quite unlikely that it would happen on both wheels, plus that I haven't had the brake pads replaced. Or is there some other problem and the rear brakes do not release properly?
    Another thing I'm wondering is if the handbrake has anything to do with it. Is the handbrake using the rear discs or is there a secondary system there on a 1996 A4?
    Coincidence or not...I noticed the noise recently and
    1) the car was serviced a 5 weeks ago
    2) the rear tyres were replaced 4 weeks ago
    3) the weather was hot enough to drive with the windows open (the noise is audible only with the windows open) in the last 4 weeks
    Normally, given 1 and 2 I'd say the garage did something dodgy, either not fitting the pads properly after removing them for inspection for 1 (but then they put the front pads back correctly) or not tightening the wheels after 2. Would under/over tightening of the wheel bolts cause something like this?
    But given 3 I am not sure, plus I've used the garage for a few years and they are always good, helpful and have never made any mistakes or tried to overcharge or force things on me.
    I booked the car in with them for next week but I'd like to see if anyone has any ideas before I take it there.
    Thanks for any insights.
  2. Re: Rear disc brake noise
    Your bearing is about to break down! In a few Km you will star listening to that strange bearing rolling noice!
  3. Re: Rear disc brake noise
    Sep 2007
    yorkshire
    Quote Originally Posted by panos.v View Post
    I would say so!
    Is it metal to metal scrapping?
    2003 AUDI AVANT SPORT TDI
  4. Re: Rear disc brake noise
    Sep 2007
    yorkshire
    EDIT, Just noticed the date. It's months old.
  1. Disc Brake problems?!?!?! or not?!?!?
    By radneo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-06-2007, 09:12 AM
  2. Rear Disc Advice
    By kenek49 in forum Archive posts
    Last Post: 10-06-2007, 04:56 PM
  3. Front Brake Disc Size for Bora TDI 115bhp?
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 16-05-2007, 09:35 PM
  4. rear noise on s3
    By markclemo in forum Audi A3 - Archive Topics
    Last Post: 06-03-2007, 09:48 AM
  5. Vento rear disc conversion
    By SV650s in forum Vento - 1994 - 1998
    Last Post: 19-09-2006, 02:31 PM
