Thread: seat cordoba over fuelling can you help ? maybe same as mk2/3 golf engine
  1. seat cordoba over fuelling can you help ? maybe same as mk2/3 golf engine
    SHEFFIELD
    Just seeing if anyone has any idea with this,a kid at work has one and its using amazing amounts of petrol,he has tried the lambda's etc but still the same after plugging it in the fault code its bringing up is 00519 map sensor faults or also intake manifold pressure listed on same code has anyone any ideas on this as he is stuck and losing faith,i know my mate had a mk2 gti which had the same problems with using too much fuel but that was the common temp sensors on that does anyone know if this maybe the same of where to start looking for faults for that fault code?
    I dont work here for the pay,or the enjoyment,so why do i work here
  2. Re: seat cordoba over fuelling can you help ? maybe same as mk2/3 golf engine
    Dec 2009
    hounslow
    check for air leaks, cracked or perished rubbers in the intake system.
  1. DSG Brakes On To Engage Drive
    By asm51 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-04-2010, 10:10 AM
  2. retrofit heated seats to 2003 A4 Cabriolet
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2010, 09:55 AM
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. New bentley continental supersports convertible
  5. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
