Thread: Tyre Recommendations for 18 inch rims please?
Results 1 to 10 of 19
  1. Question Tyre Recommendations for 18 inch rims please?
    Jul 2010
    Redditch, UK
    Hello,
    I have tried searching but as you can imagine there is a lot to go through on this subject!
    I have an 05 A4 2.0T SLine with 235/45/18's. Two of the tyres are Conti Sport Contact3 and the other two are Dunlop Sport SP Max.
    I have nothing against either of these two tyres, but I am open to suggestions.
    My boy racer 'drive it like its stolen' days are long gone, but I still enjoy a blast every now and then so I would probably lean more towards a quieter tyre rather than one that gives ultimate grip.
    So, recommendations please !
    James
  2. Re: Tyre Recommendations for 18 inch rims please?
    Jun 2010
    Kings Lynn, Norfolk
    Are you sure you are on 235/45/18s mine are 235/40/18
    as for tyres stick with the Conti Sport Contact3 mine handles like its on rails,
    you rearly have to be pushing very hard to unstick these.
    170 bhp s line bose, cruise control, pdc, mfsw, flawless glossy black, Now hopefully reliable with it's new injectors
  3. Re: Tyre Recommendations for 18 inch rims please?
    Jul 2010
    Redditch, UK
    Ah, well spotted! Yes, 235/40's it is!
    Thanks for the reply
  4. Re: Tyre Recommendations for 18 inch rims please?
    Jul 2009
    wales
    i use bridgestone s001 235, 40 18 inch, there very good tyres
  5. Re: Tyre Recommendations for 18 inch rims please?
    Aug 2009
    Near Lanark
    21 Post(s)
    Try tyre reviews for some ideas
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  6. Re: Tyre Recommendations for 18 inch rims please?
    Aug 2009
    Reading England
    I have tried the following:
    Michellin PS2 - Excellent but very expensive
    Bridgestone potenza RE050A - Excellent in wet and dry
    Continental CSC3 - Excellent grip but wear very quickly
    Goodyear eagle F1A - Excellent in wet and dry and best priced of the lot
    Out of the 4 mentioned they were pretty much all the same in terms of performance and grip, but the Eagle F1A were cheapest to buy around £135 Fitted and so far seem to be lasting the longest down to 6mm after 11K.
    Audi A4 B7 2.0 Tdi S Line 170.
  7. Re: Tyre Recommendations for 18 inch rims please?
    Aug 2010
    Leeds
    Quote Originally Posted by Puresilk View Post
    i have conti sport 3's on mine, do handle well but on the quatro modles from reading on here seem to give the worst quattro 'pull', if yours is 2wd then no issue there.
    they do seem to be wareing ok but ive had michliens before which wore quick i thought.
    Had bridgestones and althought the grip was fien they did tend to ware strange.
    bang for buck i would agree the goodyears seem a nice buy they will be my choice when the contis are worn out as there a bit too steep for me.
  8. Re: Tyre Recommendations for 18 inch rims please?
    Jul 2010
    Redditch, UK
    Many thanks chaps, I appreciate the replies.
    Goodyear - never gave them a thought and yet I've always had good experiences with Goodyear tyres in the past on a wide variety of cars....
    Mines a front wheel drive so quattro pull is not an issue thankfully!
    They will need doing soon, but they are not an urgent requirement so I've got a bit of time to shop around.
    Cheers!
    James
  9. Re: Tyre Recommendations for 18 inch rims please?
    Oct 2009
    Birtley
    What is 'Quattro Pull'?
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8.5) in Brilliant Black, B&O sound system, MMI 3G+ satnav, Parking System plus, Interior LEDs, Privacy Windows
  10. Re: Tyre Recommendations for 18 inch rims please?
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by allanmb View Post
    On a quattro and using full lock on the steering the rear wheels feel like they're "pushing" the fronts. As a result the fronts seem to slip sideways and you can feel the rubber moving across the road.
    Certain tyres appear to make it more pronounced and it also seems to be more noticeable when tyres wear down, presumably due to reduced grip and the fronts more prone to sliding.
    Best way of describing is that you feel like the front wheels are "grinding" across the surface.
    I've felt it a couple of times but it's only at low speeds so typically it's in a car park or manouvering in the driveway.
  1. T5 17 inch tyre pressures?
    By ChrisG1975 in forum Wheels and Tyres
    Last Post: 19-03-2010, 10:20 AM
  2. correct tyre size for 18 inch alloys??
    By martin73 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-02-2010, 02:38 AM
  3. Tyre mistake
    By 2.7 S-line in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-08-2009, 06:53 AM
  4. Audi A6 2006 Avant - 19 inch alloy help with tyre size
    By bdm2510 in forum Wheels and Tyres
    Last Post: 08-06-2009, 09:29 PM
  5. Tyre recommendations - V5
    By Plug in forum Golf MK4 - 1999 - 2004
    Last Post: 06-02-2008, 06:52 PM
