Thread: Manifold cleaning & common rail fuel system - help needed
  1. Manifold cleaning & common rail fuel system - help needed
    Sep 2007
    Bookham, Surrey
    Hi - is there anyone in the Bracknell/Reading/Camberley area with experience on Common Rail fuel system who fancies helping out with a strip-down and clean of the intake manifolds on my 3.0tdi? Happy to return the favour
    Or can anyone recommend a good mechanic in the same area with a reasonable day rate?
    Looks like the job will involve dismantling some of the high pressure common rail fuel system over the top of the engine so I'd really like someone with some experience with me!
  2. Re: Manifold cleaning & common rail fuel system - help needed
    Southern County Softy
    20 Post(s)
    I have no previous with the high pressure but am willing to help
    undo a few nuts.......
    A4 2.5 tdi QS (mapped)
  3. Re: Manifold cleaning & common rail fuel system - help needed
    Sep 2007
    Bookham, Surrey
    Thanks Kite - much appreciated. I've got the workshop manuals so I can start to work out what's involved and what we might be getting into. Looks like the fuel system will self purge as long as the HP pump is primed...
  4. Re: Manifold cleaning & common rail fuel system - help needed
    20 Post(s)
    don't know when you plan on doing the work but I'm away for the next couple of weeks.
    Also I work shifts so if you plan for work on the weekend give me a bit of notice please....
  5. Re: Manifold cleaning & common rail fuel system - help needed
    Aug 2015
    enjoying the community spirit, keep up the good work
  6. Re: Manifold cleaning & common rail fuel system - help needed
    Feb 2015
    GB
    You don't need to undo hp lines it's only 2 lines over the top and they are not hp when the engine is off. A couple of bugger bolts to get to you will need a long Allen key aswell. On the left bank as you look at it the top right bolt will stay in as you lift it off and a tab on the right bank will need bending back it's on the left side second bolt up iirc. If your doing this i would also say to the actuator arms aswell they are only Ł8 each from audi. As to cleaning i used a bucket of diesel and let them soak and then scrapped off the crud.
    Sent from my E6553 using Tapatalk
  7. Re: Manifold cleaning & common rail fuel system - help needed
    Aug 2012
    Aberdeenshire
    If you are going to take off the manifolds, get the swirl flap bearing and flap kit as a minimum from Airshox, a site sponsor (i believe??) as the swirl flaps are a known problem with this engine.
    AirShox Brochure_EN.pdf - Google Drive
    Cleaning is a bit of an ****, but can be done.
    Of course Airshox do a complete manifold option too if you don't want the hassle……...
    There are some rubber gaskets IIRC on the top and bottom manifolds to replace, but a soak in near boiling water can rejuvenate them if you don't get all of them
    I don't recall anything too difficult - a little patience was all it took.
    I also recall the bracket needing a small amount of bendage
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon SOLD
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue SOLD
    2006 A6 Allroad 3.0 TDi, Blue - getting ready to get rid of
    2008 A5 3.0 Tdi Quattro Coupe, Grey
    2010 A6 Allroad 3.0 TDi, Blue
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  3. All-new audi a8 travels light to miami debut
    Last Post: 16-12-2009, 06:00 PM
  4. allroad tdi 2.5 air in fuel :(
    By m6rk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2007, 01:09 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
