Thread: Boost check on VAGCOM (VCDS)
Results 1 to 10 of 16
Threaded View
  1. Re: Boost check on VAGCOM (VCDS)
    Nov 2009
    Ireland
    Cheers..
    Whats a VNT turbo?
    Graph attached is maxing at just under 1.6 bar and actual appears to be tracing well from what I can see.
    Was hoping for a little more though!!
    Is the N75 operation ok?
    Am I right in saying that when at ≈90% the valve is almost closed and almost full exhaust gasses are spinning the turbine?
    Is it correct to tail away like that over the rev range?
    Any info appreciated..
  1. Vagcom/VCDS User Locations
    By Col in forum VCDS - Users Locations
    Last Post: 05-04-2025, 07:00 PM
  2. VCDS 908.2 / 311 vagcom, won't find #46 cent. conv on 2001 A6 tdi ... help!
    By jontawn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2010, 11:22 PM
  3. Replies: 1
    Last Post: 23-06-2010, 10:19 PM
  4. Can VCDS check cruise control ?
    By BILKO1 in forum VCDS - Help Requests
    Last Post: 23-10-2009, 03:21 PM
  5. boost.... what boost???
    By mat_wye in forum VCDS - Help Requests
    Last Post: 06-06-2009, 08:32 AM
