Thread: Brake pad warning light
  1. Brake pad warning light
    Aug 2010
    Bristol
    I have a 52 reg A3 TDI quattro. The brake pad warning light is on. From a quick look neither the fronts or rear look that low. Whats the best way to diagnose which pads need replacing, or could it be a problem with the sensor?
  2. Re: Brake pad warning light
    Mar 2008
    High Wycombe
    The warning light should only be on the front pads.
    By a quick look, do you mean glancing through the spokes of the wheel? This won't tell you how much is left of the inner pad, which is the one with the indicator.
    The easiest way to tell is to whip the wheel off, and look at the pads from the edge of the brake disk. That should tell you how much is left of each one.
    If none of them look very thin, then you may have a break in the wire. The sensor is jsut a small loop of wire in one pad - when it wears on the disk, is breaks, so the circuit is open, which sets off the pad warning light.
    Changing the front ones took me about 40 minutes on my front drive the other day.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Brake pad warning light
    Aug 2010
    Bristol
    Quote Originally Posted by NickPicks View Post
    Brilliant, thanks for the help. I shall have a looksie tomorrow.
    Oh, by the way, how can you tell if it needs new discs? Or will it be ok to put new pads on the current ones.
  4. Re: Brake pad warning light
    Mar 2008
    High Wycombe
    Unless the discs are particularly lipped, or have grooves around them, or are very thin, I'd put new pads on old discs.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Brake Light Conundrum?
    By Eags in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2010, 11:17 PM
  2. Brake Pad warning light
    By Boy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2009, 11:26 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Brake Pad warning light?
    By les in forum Passat - Archive Topics
    Last Post: 27-11-2006, 09:51 PM
