Thread: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    Nov 2015
    Aberdeen,Scotland
    Presumably the new bolts are easier to stretch than the original ones, so it might not be any more difficult than 90+90. I could probably borrow a torque multiplier to ease the install.
  2. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    133 Post(s)
    1987 Post(s)
    There is more to it than reviving a five year old thread, I have had rather a lot to drink in the last five years so lets have a new thread which starts a story....
  3. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    Jun 2015
    I've done the 150nm +1/2 turn bolt and I'm quite weak TBH. Just used a 600mm 1/2 drive breaker bar and used my weight. You should lightly oil the bolt threads and washer face as in the workshop manual. I did also have the crank pulley locking tool jammed against the ground so could use both hands!
  4. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    Nov 2015
    Aberdeen,Scotland
    I did the job last week, and installing the bolt was a doddle (I have the correct pulley holding tool - I can see that it may be a struggle without it). I used an ISS impact socket, AST 600mm extension, and a Bergen 39" 1/2" bar.
    The only problem I had with the job was figuring out how to remove the alternator belt tension pulley (and getting the water pump off without damaging the block).
    It was also illuminating when I tried to purchase new engine mount bolts and a new pulley bolt from Hawco. When they do a cambelt change they reuse the bolts (I thought authorized dealers would go by the book) - they only replace bolts supplied with the belt kit.
  5. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Glad you got it done no probs - I think a lot of torque to yield bolts just end up getting reused
  6. Re: 1.4 16v BKY - Crankshaft Pulley Bolt & counter hold tool
    133 Post(s)
    1987 Post(s)
    Quote Originally Posted by Rob69 View Post
    Yes, we had a Leon in the other week where someone had re-used the gearbox mount bolts after a clutch - the box literally fell out! Two M12x1.5 Time Serts, a new engine mount and new genuine bolts fixed it. We NEVER re-use bolts that ELSA says to replace. In our stores we have an alcove with three walls floor to ceiling with genuine VAG fasteners.
    0 2 0
  1. Question 2001 Passat 1.9TDI all belts and alternator pulley replacement
    By wonkey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-09-2011, 06:28 PM
  2. Question 2.5 tdi afb engine crankshaft pulley locking pin location
    By rsmtechnicians in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2010, 10:49 AM
  3. How To change radiator in 1.9 tdi
    By Shaun. C. in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-05-2008, 07:46 AM
  4. fabia 1.4 16v - cut out problems?
    By monkeyalan in forum Fabia
    Last Post: 27-03-2008, 02:58 PM
  5. Polo 1.4 16V AUA - timing tool
    By roypch in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2007, 11:34 PM
