Thread: Center Console Removal
  1. Center Console Removal
    Sep 2010
    salford
    I have just purchased a 2007 passat sport 170 dsg, I am trying to find out how to remove the centre console - I am trying to get power to headrest dvd and was assuming I can take it from the rear 12v socket?
  2. Re: Center Console Removal
    Jan 2010
    Lisburn, United Kingdom
    Firstly, welcome to the forum!
    The problem with taking it from the socket will be that the power will cut out with the ignition ie when you turn the engine off. This has been an issue with other members of the forum.
    Your best bet will be to take a supply from the fuse box and fed a wire down the centre console. Simply tuck it up under the plastic and it's out of sight. This means you can also add an extra fuse in the circuit.
  3. Re: Center Console Removal
    Sep 2010
    salford
    Quote Originally Posted by g-black View Post
    Ideally I want the power to cut off when engine is off, as I know my wife and kids will simply leave them running and zip them up.
    Do you know how the console is fixed (just the rear part)
  4. Re: Center Console Removal
    Feb 2010
    Louth Ireland....
    Take off the plain black cover below the rear socket and undo the two screws and the whole back piece comes off...........see picture below
    Ex Passat B6 owner......to many retrofits to mention !
  5. Re: Center Console Removal
    Sep 2010
    salford
    Quote Originally Posted by richiemac View Post
    Thanks alot, all working fine now.
  1. Center Console Installation
    By needtogetfit in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2009, 11:12 PM
  2. How does the Quattro system work?
  3. Center console removal
    By schoey1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-06-2007, 02:38 AM
