Thread: Do MK V accessories fit MK VI?
Results 1 to 10 of 10
  1. Do MK V accessories fit MK VI?
    Jul 2008
    We have just ordered a Mk VI having had a couple of Mk Vs. Just wondering, seen as the new car is closely related to the old version, if the following Volkswagen MK V accessories also fit the MK VI?
    Roof Bars
    Flexible bootliner
    Rubber mats
  2. Re: Do MK V accessories fit MK VI?
    South London. UK
    Quote Originally Posted by Red 2 View Post
    Roof Bars
    Flexible bootliner
    Rubber mats
    Why not check with the main dealers?
    However I would think that the boot liner and interior rubber mats would fit their available spaces. In fact my MK5's rubber mats are in my MK6 although the securing turn buttons of the MK5 are not present - just stubs in the same place.
    Roof bars - I don't know.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  3. Re: Do MK V accessories fit MK VI?
    Jul 2008
    Cheers.
    Main dealer (sales) didn't know and by the time we had finished haggling, the desire to leave quickly was overpowering!
    Time for a call to parts.
  4. Re: Do MK V accessories fit MK VI?
    Feb 2009
    Re Mkv - vi accessories. I bought the bootliner for mkvi before i took delivery and tried it for size in my mkv and it fitted Ok, as in other posts the clip arrangement for floor mats has changed ie twist clip now just round stud in mkvi - but have used my mkv mats front & rear and they fit fine - no movement with front..sorry cant help on roof bars
  5. Re: Do MK V accessories fit MK VI?
    Jul 2009
    Glasgow
    According to http://www.roofbox.co.uk/ its the same part number for both.
  6. Re: Do MK V accessories fit MK VI?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Well the Mk6 roof bars are called
    1 base carrier set section: T-groove - 1K0 071 126 - £162.
    The Mk5 is exactly the same description, part number and price, expensive.
    The roof bars are sucurly mounted with a lockable key with 200 key combination.
    The flexible loadliner is - 1K0 061 161 - £42.
    The front rubber mats black are 1K2 061 501 A 041 - £30.50
    The rear rubber mats black are 1K0 061 511 041 - £26
    They are in the link below
    The same roof bars here are £197,
    http://www.volkswagen.co.uk/assets/c...ccessories.pdf
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: Do MK V accessories fit MK VI?
    Feb 2007
    The floor securing arrnagement in the Mk5 had two variants - later cars with the round studs are the same as the Mk6.
    My mats are actually a Mk5 part number.
    2010 Golf Mk6 TDI105 SE - now departed, replaced with A3 Sportback
  8. Re: Do MK V accessories fit MK VI?
    Feb 2010
    Hertford
    Roof Bars
    Flexible bootliner
    Rubber mats
    Had an interesting experience with roof bars in France.
    Staying with relatives and offered a 350 litre roof box if we could get it home.
    Went to French version of Halfords - mont blanc manufactured roof bars for equiv. of £120, problem was only referred to as fitting Golf Mark 5.
    Spoken French not up to asking shop assistant whether they would fit a 6, so went to nearest VW dealer.
    He was very careful in checking car's VIN number, then placed the order for Mark 6 roof bars for next day delivery, cost £155. Again, didn't have ability to ask dealer whether Mk 5 bars would fit.
    Bars turn up next day as promised. What does the box say? Roof Bars, VW Golf, 2004 on. So, they were mark 5 bars after all. They fit a mark 6, the fixing points must be identical.
    GT 1.4 ACT, Urano Grey, Climatronic
  9. Re: Do MK V accessories fit MK VI?
    Jul 2008
    Thanks to all for the information.
    It appears that the roof was carried over untouched from the MKV so hence the roofbars still fit.
    Saves a few pennies when mats etc. can all be transferred!
  10. Re: Do MK V accessories fit MK VI?
    Oct 2009
    Chepstow UK
    I had a Mk V with roofbars (VW) and mats (VW) which I traded in for a new Mk VI about 9 months ago (both 5 door versions). I wanted to keep the bars and mats because of the cost of new ones and found that the roof panel and floor pan of the Mk VI were unchanged in these areas. The Mk V bars and mats fitted the Mk VI with no problems. There is a small difference on the fitting of the front roof bar. On the Mk V the bar is located by two pointed studs which go into plastic inserts just above the door. On the Mk VI the plastic inserts are replaced by two metal threaded inserts in the same locations. These have plastic plugs in which you need to remove to fit the bar. The studs on the bar fit in the normal way. The threaded inserts are probably for a feature thats on newer roof bars but its backwards compatible.
  1. How To DIS AND CRUISE RETRO FIT b6+b7
    By a8 tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2014, 09:43 AM
  2. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  3. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  4. Tdi Sport 2006 Alloy Wheels Not Fit Mk4
    By drfe11a in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2008, 09:13 AM
  5. Volkswagen Express Fit saves customers money
    Last Post: 03-07-2004, 08:18 PM
