Thread: 2.0 TDI hesitating at low revs
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
  1. Re: 2.0 TDI hesitating at low revs
    #61
    Aug 2012
    uk
    Hi im new to this forum so firstly hello all. Secondly the problem that you are all experiencing happens during EGR on/off, I have cured 3 tdis that hesitate/misfire symptom all happen around 1500/2000 rpm usually town driving or just gone over a speed hump. Anyway there is a modified egr gasket that goes on the pipe directly onto the EGR instead of the big hole that matches the diameter of the pipe and EGR its a gasket with a smaller hole. Ill see if I can dig the part number out but might be a week or so before i can.
  2. Re: 2.0 TDI hesitating at low revs
    #62
    Apr 2010
    Ashford, Middlesex
    Interesting - is it a hard thing to swap out?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  3. Re: 2.0 TDI hesitating at low revs
    #63
    Aug 2012
    uk
    Quote Originally Posted by fat controller View Post
    No 5 mins max two bolts pull the pipe out and replace gasket. If you take the engine cover off it's right at the front of the engine. I'll try and get the part number of the gasket for you this week.
  4. Re: 2.0 TDI hesitating at low revs
    #64
    134 Post(s)
    2007 Post(s)
    069 131 547 D, nothing special about it though, a 32-mm bore gasket, £2.60 from VW.
  5. Re: 2.0 TDI hesitating at low revs
    #65
    Aug 2012
    uk
    Hi no that's the standard gasket. Just got the part no its 028 131 547B has about a 10mm hole
  6. Re: 2.0 TDI hesitating at low revs
    #66
    134 Post(s)
    2007 Post(s)
    9-mm hole hot end gasket mainly used on the Golf 3/Passat with the AAZ 1.9 TD 75PS engine. I can see no campaign or TPI info about using this on the cold end of the EGR system and I worry this would cause a restricted flow code. Where have you seen information provided by VAG suggesting this is used?
  7. Re: 2.0 TDI hesitating at low revs
    #67
    Aug 2012
    uk
    No it doesn't log any restricted air flow faults or any other fault. Can't remember where I got this info from.
  8. Re: 2.0 TDI hesitating at low revs
    #68
    Aug 2012
    London
    Quote Originally Posted by jam123 View Post
    Hi guys and gals
    i'm having the same problem as all with the juddering at 1500 to 2300 rpm. has any one tried the gasket change?
  9. Re: 2.0 TDI hesitating at low revs
    #69
    Apr 2007
    France
    12 Post(s)
    13D8 - have a look under the boot carpet, there might be a sticker there to say it's been done. Still doesn't mean it hasn't been done if there's no sticker.
    It's not connected to your problem of course. There was another 'recall' to fix low revs bogging down, can't remember the code but it was done on mine (96/97 model). That was another boot sticker.
    Dealer should be able to check for you.
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: 2.0 TDI hesitating at low revs
    #70
    134 Post(s)
    2007 Post(s)
    13D8? Isn't that the recall for cars with the early 2006/7 spur gear drive failure issue/? Too late to look it up...! Ohh God I should not know these numbers off the top of my head, going to bed now...
  1. Kerb weight changes for Golf 2.0 TDI
    By Bogester in forum Golf MK6 - 2009 - 2013
    Last Post: 27-02-2010, 02:54 PM
  2. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  3. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  4. Replies: 0
    Last Post: 03-12-2005, 07:54 PM
