Thread: Rear Parking Sensor
  1. Rear Parking Sensor
    Dec 2009
    bolton
    I have a 2.5tdi 2004 (auto box) B6 when I place the car in reverse I get a long "beep" and none of the sensors register, I presume one of the parking sensors has failed.
    Do you have to remove the whole bumper to replace ? and if so how ?
    Where is the cheapest place to purchase a new genuine audi sensor ?
    Any help would be grateful
  2. Re: Rear Parking Sensor
    May 2010
    Devon England
    if you have it scanned it will tell you which sensor is faulty, ive done this using a snap on scanner in the past, iirc you can reach up behind the bumper and compress the 2 clips and push it out, if i was you id try TPS or GSF, gsf wont sell a genuine one but its worth a call to check on price
  3. Re: Rear Parking Sensor
    Dec 2009
    bolton
    Thanks for the advise - will give it a go of reaching under the bumper and try pushing out the sensor
    Thanks again
  4. Re: Rear Parking Sensor
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    If you have no access to scan equipment ,select reverse with ignition only and place your ear to each sensor,the one that is silent is the offender,strangely quite often the nearside unit
  5. Re: Rear Parking Sensor
    Dec 2009
    bolton
    Thanks ordered a Vag Com lead tried to feel under the bumper to gain access to the sesnors - no chance of this, only problem now is that I will have to take the car into a garage to have the rear bumper taken off. Unless someone can explain an easier way to replace the sensor
  6. Re: Rear Parking Sensor
    Sep 2010
    Durham
    There is another way to check without using VAG COM. If you make sure the sensors are on and then go around the car listening to them (ear as close as you can) you'll here the good ones "click" repeatedly. The dead ones won't. If one sensor fails the entire system will not work.
    I usually buy sensors on Ebay for around £30 - £40. Be carefull removing/replaceing the sensors. I've pulled good ones apart in the past as the top bracket sometimes unclips themselves.
    Just noticed that I've repeated the same info from Fourringsrus... !! lol... Well "if 2 doctors say you're ill..."
  7. Re: Rear Parking Sensor
    Feb 2010
    Sudbury
    Easiest way is to drill the old ones out ,discard the old bits, feed the new ones in and tywrap the new one's leads to the inside of the bumper. Take off the passenger side boot lining and you will find the original control box with a lead going up to the sounder under the rear shelf directly under the rear windscreen. Just put your new control box where the original one was and tuck the new sounder near the old one. Took me half a day to do it.
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. A6 Rear Parking Sensor alarmed by Tow Bar
    By Ken895 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-05-2008, 11:04 PM
  3. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
