Thread: Window regulator
Results 1 to 9 of 9
  1. Window regulator
    Mar 2010
    Rayleigh uk
    Hi There,
    Can anyone tell me how easy or difficult it is to change the window regulator on an A4 Cabriolet, front drivers window. The window stopped moving half way up and whenever I push the window button to sounds as though something in the door panel is eating a light bulb, munch munch you get the picture! Any help or instructions would be much appreciated!
    Many Thanks
  2. Re: Window regulator
    Dec 2008
    sounds like your glass may have come off its rollers, i would get the door opened and have a look inside before forking out for a new regulator....incidentally, the regulator swapover is quite simple, just unscrew and unclip and put new one in and clip it back up.
  3. Re: Window regulator
    Nov 2010
    Northampton
    Sounds an obvious question but what does a regulator look like?
    Rich
  4. Re: Window regulator
    Dec 2008
    Quote Originally Posted by Richard C12 View Post
    Rich
    see this auction listing which has a good image of what it looks like :-
    http://cgi.ebay.co.uk/AUDI-A4-8E-B6-...item2eaf84f9e6
  5. Re: Window regulator
    Feb 2010
    Norfolk uk
    hi,i have window problem as weell my pasenger side wont go up or down,it just makes a clik sound when i push the button,i did a scan and it came u p with this:
    VCDS-Lite Version: Release 1.0
    Saturday, 30 October 2010, 14:44:05.
    Control Module Part Number: 8E0 959 433 AC
    Component and/or Version: Komfortgerát T9F 0313
    Software Coding: 06858
    Work Shop Code: WSC 63351
    Additional Info: 8E2959802B Tõrsteuer.FS BRM 4.11
    Additional Info: 8E2959801B Tõrsteuer.BF BRM 4.11
    1 Fault Found:
    01332 - Door Control Module; Passenger Side (J387)
    37-00 - Faulty
    the dors are unlook aand lok just fine it s just the window thats not working,is it the window regulator??? i don t know wich one is the door control module,
    sorry for hijaking the post
    regards laur
  6. Re: Window regulator
    Feb 2010
    Norfolk uk
    Nobody????!?
    Sep 2009
    ramsgate
    Try the windows but give it some help, open the door and clamp glass between hands push down as someone pushes the switch. If it goes then something is jammed or too tight, can happen in the cold. The click is the safety to stop damage to the motor.
  8. Re: Window regulator
    Feb 2010
    Norfolk uk
    i ve been speending the last hour or so to to that but with no succes,any other ideas???
    many thanks laur
  9. Re: Window regulator
    Feb 2010
    Norfolk uk
    uodateroblem solved it was the motor it was only going up,second hand one now in and all back to normal
  1. n/s/f window regulator
    By estate130 in forum Bora - 1998 - 2005
    Last Post: 07-07-2010, 12:59 PM
  2. Window regulator - advice?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2010, 01:04 PM
  3. Window regulator works backwards
    By Equinoxstudios in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2009, 12:24 PM
  4. Window regulator replacement parts
    By deucedano in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2007, 08:41 PM
  5. Replacing Window Regulator - is it an easy job ?
    By Paul Marsland in forum Touran - Sharan - Caravelle
    Last Post: 14-05-2007, 12:27 AM
