Thread: leaking out of fuel cooler
  1. leaking out of fuel cooler
    May 2010
    edinburgh
    please help!!!hi posted with intermittent cutting out problem and have since found diesel coming out top of fuel cooler,on top of fuel filter,seeping up side of big hex bolt that goes through the middle.filter was changed not that long ago,tried to tighten but still happening.
    got another filter,which has a rubber seal in the top of it,is this the only rubber seal,or do i have to get another one for under the head of the bolt?hope this makes sense,hoping someone who has done this can guide me through the process,and what i need to get before i start dismantling,cheers adam
  2. Re: leaking out of fuel cooler
    Engine code required. Regards Peter
  3. Re: leaking out of fuel cooler
    May 2010
    edinburgh
    hi peter,fitted new filter,problem sorted,many thanks,adam
  1. Question Fuel range over estimated
    By bfradio in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-11-2009, 07:47 PM
  2. Fuel leaking or blocked
    By mattyryder in forum Golf MK4 - 1999 - 2004
    Last Post: 05-06-2009, 09:54 PM
  3. A6 Fuel Leak
    By rtdc in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-12-2007, 03:10 PM
  4. is my passat leaking fuel
    By kharva007 in forum Passat - Archive Topics
    Last Post: 02-03-2007, 08:25 AM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
