Thread: Retrofitted RNS-510, Changed GW, now a lot of errors
Results 1 to 10 of 41
  1. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Sep 2010
    Spain
    The failures continue and add another, more
    VCDS Version: Release 908.1
    Data version: 20091018
    Sunday,12,September,2010,15:49:10:46862
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 7D
    VIN: WV Mileage: 90400km/56171miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Cannot be reached 1100
    56-Radio -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: Not registered 0011
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
    Component: R4 2.0l PPD1.5 G 9627
    Revision: --H05--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00311 572 86198
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0658494146
    Coding: 0015650
    Shop #: WSC 00028 028 00001
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA
    Component: ClimatronicPQ46 050 0404
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000003717476
    Coding: 05800F0700041A00020A00000F00000000095D435C0000
    Part No: 3C1 955 419
    Component: Wischer VW461 001 0101
    Coding: 00063445
    Shop #: WSC 00028
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 04 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PQTFWS+
    Coding: 0012340
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenksäulenmodul 005 0010
    Revision: 00005000 Serial number: 3C5953507C
    Coding: 0000013
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 870 Q HW: 3C0 920 870 Q
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0033000 Serial number: 00000000000000
    Coding: 0007105
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3690P106150889
    Coding: F9807F06400202001002
    Shop #: WSC 00079 790 00000
    4 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 90406 km
    Time Indication: 0
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 90406 km
    Time Indication: 0
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 90406 km
    Time Indication: 0
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 90406 km
    Time Indication: 0
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
    Component: IMMO 038 0367
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    Part No: 3C0 905 861 D
    Component: ELV 024 0370
    3C0905861D ELV 024 0370
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2365
    Coding: 0000181
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 038 0455
    Coding: 01910A0801864E763804141570084F0E503C00
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000180
    Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    005 - No or Incorrect Basic Setting / Adaptation
  2. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Norfolk
    My mistake. Your original coding was correct. Do the original code again but make up some numbers for workshop code, Importer, Equipment. Something like 1234.....123....12345.
    This is what ross-tech recommend.
    Then try to open module 37 navigation. If it opens have a look at the coding.
  3. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Sep 2010
    Spain
    My mistake. Your original coding was correct. Do the original code again but make up some numbers for workshop code, Importer, Equipment. Soething like 1234.....123....12345.
    I tried changing the values for workshop code, Importer, Equipment and will not let me change them. How could I?
  4. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Norfolk
    If it won't change then you can't change it. I am out of ideas. You could try recoding the gateway to F9807F16500302001002. This should not work but it is worth a try.
  5. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Sep 2010
    Spain
    that does not work, the end I will return the gateway to the ebay seller, thank you very much for everything
  6. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Sep 2010
    Spain
    The eBay seller told me this:
    "You need to cut pin 2 inside the box. Like on the 530 L. Otherwise no.
    This fault is from the RNS-510, I think it is bad coded. He needs to remove unit 37 and 56 from the Can gateway, remove key from car, and reinsert key in car. login into can gateway again remove errors, and add unit 37 & 56 again and test for errors.."
    and I have seen this in another forum:
    Hey.
    The part number is : 3C0907530 and should end with either H, L or Q but remember if you intall the L or Q version you have to take the gateway apart end cut the 2. pin from the right otherwise the gateway will be toasted and you have to buy a new one.
    The can gateway is placed just left of the gas pedal and a little up there is a 20 pin blue plug in it.
  7. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Norfolk
    I have never heard of cutting pins before. I would not do that as the gateway may end up as scrap.
  8. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Jul 2009
    Singapore
    Hi Guys,
    1. I am currently driving Passat Variant B6 2.0T 2007.
    2. Please see pic of old & new CAN gateway.
    http://img651.imageshack.us/img651/6...3644resize.jpg
    Left: Original CAN gateway. Right: New CAN Gateway
    3. My installer has already installed the RNS510 (LED version) and reverse camera installed.
    4. The new CAN gateway has the ‘back-up cam’ (6C) option available. The old CAN gateway does not have this option. The other purpose of upgrading the CAN gateway is to prevent battery draining.
    5. When we switch on the ignition & select reverse gear:
    a) the ‘bulb blown’ indicator lights up
    b) the reverse light on the rear does not light up. No voltages.
    c) reverse cam doesn’t work. Nothing happened/showed up on the RNS 510 screen.
    * We copied the old CAN gateway settings to the new CAN gateway settings. Only include “back-up cam” option on the new CAN gateway.
    6. The faults which i mentioned in 5(a) & 5(b) will only go away after he swapped back to the old (original) gateway.
    Questions:
    a) Is this the correct new CAN gateway for the Passat Variant B6
    b) One of the thread mentioned, one should cut ‘pin 2′. Can anyone elaborate more on why this should be done. Is this related to what i am encountering now?
    c) The reverse camera module wirings are OK (with the original/old CAN gateway) because he tried connecting the output to a portable DVD player, put to reverse gear, and there is picture on the portable dvd player. This experiment was done while waiting for the new CAN gateway.
    Please advise.
    Thanks in advance.
  9. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    Norfolk
    Quote Originally Posted by drizzt dourdem View Post
    Did you try at the start page. under settings and user interface. Change codes from 00000 etc to 12345 etc.
    That should work. Then recode with you original 10 byte code.
  10. Re: Retrofitted RNS-510, Changed GW, now a lot of errors
    I test all 530Q gateway that I have on a Passat 3C 2008,
    this Passat come with 530E,now using 530L,all work well.
    and I test all 530Q on this 2008 Passat today.
    my VCDS 10.6.1 set code as 12345, importer as 123, equipment number as 12345
    all 530Q have this error code.
    can't communication with RNS510
    at this moment, I think 530L is the best choice,
    but it was dropped and replaced by 530Q in ETKA.
  1. Replacement Steering Rack has changed steering
    By xandertarr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-04-2017, 10:46 AM
  2. Replies: 8
    Last Post: 23-08-2010, 12:16 PM
  3. 2004 Golf Mk4 1.4 Match - Misfire & Brake Switch Errors.
    By mlilburn in forum Golf MK4 - 1999 - 2004
    Last Post: 26-11-2009, 08:45 AM
  4. Touchscreen RNS 510 Sat Nav
    By Trikster in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2008, 05:19 PM
