Thread: VW Passat 2005 after market stereo issues
  1. VW Passat 2005 after market stereo issues
    Sep 2010
    Dublin, Ireland.
    I recently acquired a Meos double DIN after market car stereo.
    I picked up a harness to convert the adapter to ISO from Halfords.
    Problem is the stereo wont power on/off with the ignition, this is causing an annoying LED light to stay permanently on.
    I understand the ISO adaptor has two power leads red/yellow and that it requires a constant 12v and a ignition 5v/12v when ignition is off/on respectively.
    I got out a multimeter and checked the connections from the VW lead, it appears there are 2 12V power and one 12v/5v adaptor, this appears to be giving 12v when ignition is off and 5v when ignition is on which is the wrong way around. Can anyone advise what my problem is here?
    Also, the annoying LED on the stereo, how long would you reckon this would take to drain a battery?
  2. Re: VW Passat 2005 after market stereo issues
    May 2008
    The car doesnt use a standard 12v ignition feed at the stereo, it uses 12v perm live and the other wire is switched through the CANBUS network to signal the radio to turn on/off.
    You need to provide a 12v ignition feed, Therefore you need to run a wire from a suitable feed at the fusebox to the stereo harness.
  1. Advice - Buying VW Passat Highlint 4motion 1.9 TDI
    By zherlock in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2009, 11:14 AM
  2. Please Help 2005 Passat TDI PD 130 bhp Timing Belt Change
    By knoxman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2009, 10:05 AM
  3. 2005 vw caddy stereo
    By gerrysmith in forum The Commercial Range
    Last Post: 07-04-2008, 09:51 PM
  4. The Passat Bluemotion – Uk Market Information
    Last Post: 02-05-2007, 07:28 PM
  5. Auto1 Award: The Passat is Europe’s Number One
    Last Post: 07-03-2006, 08:56 PM
