Thread: A4 1.9 tdi sport wipers slow
  1. A4 1.9 tdi sport wipers slow
    Nov 2008
    Frizington, Cumbria
    Hi
    I have a 04 A4 1.9 tdi sport with slow wipers in every position on the stork. Has anyone had the same? and whats the cause? also the what to do to rectify.
    Andrew
  2. Re: A4 1.9 tdi sport wipers slow
    Southern County Softy
    20 Post(s)
    The wiper mech. can seize up.
    There are posts on here that show how to remove and lube the mech.
    Use the search button.
    A4 2.5 tdi QS (mapped)
  3. Re: A4 1.9 tdi sport wipers slow
    132 Post(s)
    1980 Post(s)
    The driver’s side spindle will be seized. I fit a new frame as it is more cost effective nut if you have the time you can strip the spindle out of the frame and clean it up. To get the motor/frame out you have to remove the wiper arms and the lower screen trim then remove the top of the ECU water box, disconnect the wiring from the main harness at the multiplugs and then unbolt the base of the water box and swing it and the ECU out of the way, then you can get the assembly out.
  4. Re: A4 1.9 tdi sport wipers slow
    Happened to me with the drivers side spindle. Managed to free it out but a bit of a pain in the **** of a job. Best of luck.
  5. Re: A4 1.9 tdi sport wipers slow
    Chorley
    After the recent dry period I noticed my wipers were really slow.
    Read the info on here and went to remove the mechanism for repair but couldn't even get the wiper arms off! So I just liberally squirted WD40 on the linkages best I could and left until the next day hoping for the best.
    When I tried the wipers the next day they were the same, really slow. The motor stopped completely a couple of times, I planned to sort it next weekend.
    Today, as I needed the car, I lifted the wipers off the screen and turned them on and let them run. After a few minutes the speed increased slightly and soon the wipers were back to normal speed. I have used the car today in the rain and the wipers were fine (for today anyway)
  6. Re: A4 1.9 tdi sport wipers slow
    Nov 2008
    N/A
    My wipers started squeaking a year and a half ago, so I took the wipers off (using pullers) and all the associated trim, but I was too scared to unplug the ECU so gave it a clean & lube as best I could in situ. All fine until this week. Now they're going slow - lots of duck oil (all I have),and they're 80% ok for now.
    Have found this guide here and intend to do it this weekend.
  7. Re: A4 1.9 tdi sport wipers slow
    May 2007
    Under the Forth Bridge
    The guide is good. I've done it on two cars now. However only a temporary fix - as mine have gone go slow again approx a year after full stripdown and lube (first time with high temp grease and second time with copaslip).
    Job is a bit of a pain in the.... but worth it as you can be sure they will stop working altogether on the wettest day and furthest from home.
    Might be worth sticking some rainex or similar on the screen and in the boot) to help in the meantime just in case the worst happens.
    PS I ended up with no wipers 80 odd miles away from home - went into a corner shop and bought a potato, cut it open and smeared it on the screen which actually worked well enough to get me home - although obviously not reccomended!!
    Current : B6 (54) 1.9tdi Quattro Sport Avant (250k and counting), 8L (02) A3 1.9tdi Quattro Sport (5dr) (130k and counting) VW Touran 2016 2.0tdi Family SE (don't ask!)
    Previous : B6 (03) 1.9tdi Quattro SE, 8L (03) A3 1.9tdi SE (5dr)
  1. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  2. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  3. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
