Thread: steering pull
  1. steering pull
    Hi, I have recently acquired an Audi 80 Cabrio. Lovely car but I have noticed it has a tendency to veer to the left. It is not harsh but does need constant correction. I have confirmed the problem by driving on right side of the road; car still veers left over the centre line and not to the right to follow road camber as you might expect.
    It has had new front pads and discs, but a spin check reveals no excessive drag. Both sides feel the same.
    Have noted that even on flat surface at very low speed, with 'hands off', that the steering wheel gently 'kicks' to the left as the car moves forward.
    Any known history for this model before I embark on potentially lengthy troubleshooting?
    Many thanks,
    May 2007
    surrey / yorkshire
    hi,
    my old 80 coupe used to do a simlar thing and it turned out to be worn bottom arm bushes. so the trakcing was out.
    check the bushes are ok then go for wheel camber and tracking alignment.
    oh and check tyre pressures are correct too.
    hope this helps
    gareth
    Audi A4 B5 1.8T
    Thanks for response.
    Tyre pressures good. Had the tracking checked and adjusted last week.
    I have read that bushes may be a problem on this car, but on first inspection, all looks pretty clean and tidy under there?
    Does anyone have a good source for Audi spare parts?
    Martin
    May 2007
    surrey / yorkshire
    daft question? are all your tyres the same size side to side? ( eg: 195-55-15 etc)
    other than that not sure mate.
    try these guys for spares they're good for older cars
    http://www.germancarspares.co.uk/index.html
    or GSF car parts area quite reasonable
    Audi A4 B5 1.8T
    thanks tut,
    have done the obvious, tyres etc. will go for the bushes as a matter of course and take it from there.
    thanks for parts links.
    martin
  1. steering problem
    By golfmark5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-06-2007, 07:53 PM
  2. MK3 Steering Column Help
    By Alun in forum Golf MK3 - 1993 - 1999
    Last Post: 24-04-2007, 06:46 PM
  3. Bonnet Pull
    By Phil155 in forum Passat - Archive Topics
    Last Post: 02-01-2007, 06:49 PM
  4. steering rack
    By charlie oscar in forum Passat - Archive Topics
    Last Post: 19-12-2006, 12:43 PM
  5. mk3 steering problem
    By Maddoggolfface in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-11-2006, 08:24 PM
