Thread: Gearbox / Clutch Issue
  1. Gearbox / Clutch Issue
    lithium Guest
    hi all,
    VW GOLF MK5 TDi 1.9 (105) 2006
    I was driving back fromwork yesterday, i pulled out of a junction quite heave and noticed it was difficult to select a gear, anyway, i carried on once the gear was selected untill i had to come to a stop.
    I knocked the gear stick in to neutral and then couldnt select a gear, the clutch peddle was very light, no resistance.
    I managed to finaly select a gear and limped home.
    I have come to look at the car today, i pumped the clutch peddle for a while and now there is resistance... here is the weird part...
    The engine runs well and the gears engage and the clutch depresses etc etc, I just get no drive. I do not require the clutch to be depressed in order to change gears either, i can literally just cycle the gears without the clutch depressed with the engine running.
    Im thinking Input shaft has disengaged and needs to be put back into position, or differential has gone?
    Anyhelp would be great
  2. Re: Gearbox / Clutch Issue
    lithium Guest
    in case anyone gets the same symptoms;
    Clutch friction plate had torn it self to bits,
  1. Unusual Clutch Issues
    By taveirne in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 05:59 PM
  2. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  3. ** Manual Gearbox Problem 93 Polo CL Coupe **
    By VWPeoplePower in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2008, 12:09 PM
  4. Gearbox issue
    By tinnyuk75 in forum Polo - Derby - Lupo - Fox
    Last Post: 21-05-2007, 11:54 AM
  5. Whirr when clutch depressed ? gearbox bearing
    By mr g in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2007, 12:15 AM
