Thread: help...t4 transporter crankshaft oil seal
  1. Thumbs up help...t4 transporter crankshaft oil seal
    Jul 2010
    Bolton, Lancashire
    help...t4 transporter crankshaft oil seal..how easy are these to do? (its the one on the pulley side...)
    any help or advice greatly appreciated....
    T4 Transporter work-horse/shed (for now)
  2. Re: help...t4 transporter crankshaft oil seal
    Pembrokeshire
    22 Post(s)
    welcome to the forum. now, it depends which engine you have, so it would help if you could find the engine code. basically though, you need to remove the crank pulley, then the toothed pulley behind it, pull the seal out, put new one in, then rebuild it. you will need to fit a new cambelt. i presume your engine is a 5 cylinder though, as the crank seal leaking is a fairly routine job.
  3. Exclamation Re: help...t4 transporter crankshaft oil seal
    Jul 2010
    Bolton, Lancashire
    thanks for your reply mate, much appreicated indeed...just got wife's computer back after cooking it..erm, oops!!! (looking for parts for the "shed").
    The darn thing wont start at the minute...he was fine on the first of this month, the on the 2nd, he wouldnt fire up at all..engine turns over nice, but, nowt happens!! could this just be the glow plugs? or could it be more serious? The previous owner had a new diesel pump fitted (which does look pretty clean to be fair) but wife is having a fit cos i've spent loads having it repaired etc.. (new gearbox innards- twice- as the (ahem) "specialist" missed a damaged cog the first time round!!)
  1. Buying Oil, Some Basic Advice From Opie Oils
    By oilman in forum Chat - Anything with wheels
    Last Post: 13-10-2015, 11:16 AM
  2. 2000 Beetle lights, alarms, oil!
    By bluebeetle in forum Beetle 2000-
    Last Post: 23-04-2008, 04:31 PM
  3. '92 MkII 1.8 NO oil pressure
    By 2old2turbo in forum Golf MK2 - 1984 - 1992
    Last Post: 06-10-2007, 09:58 PM
  4. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
