Thread: Golf mK3, problems starting, not turning over till 3rd attempt or so
  1. Golf mK3, problems starting, not turning over till 3rd attempt or so
    1.4 P reg and she is not happy. Has started cold last 2 mornings, but after a 20 mile trip, and then left for 10mins, then today half hour she won't turn over.
    All lights on dash come on fine. If i try a couple of times it works ok. any ideas, and help much appreciated. I am not by any means a mechanic, lol so is there anything i can do myself, or check for now?
    thankyou
  2. Re: Golf mK3, problems starting, not turning over till 3rd attempt or so
    Sep 2009
    South Wales
    Does it make any noise when it fails to turn over?
  3. Re: Golf mK3, problems starting, not turning over till 3rd attempt or so
    hi there, no nothing, just turn the key and the lights come on, then try a few times and she turns.
  4. Re: Golf mK3, problems starting, not turning over till 3rd attempt or so
    Sep 2009
    South Wales
    Can someone with a voltmeter check your battery when its off/on?
    It should be at least 12v while its off, and around 14 when its running. This will let you know if the battery/alternator/belt is at fault.
    Quick way to try and tick one possibility off the list
    Could also be starter solenoid, starter motor connection, sticky starter motor, or maybe a bad ignition switch, or even an immobiliser problem
    It will be a case of narrowing all that down one by one
  5. Re: Golf mK3, problems starting, not turning over till 3rd attempt or so
    132 Post(s)
    1979 Post(s)
    Most likely, it is a sticking starter motor if it only happens when it is hot. The Golf 3 ignition switch is unreliable but it would play up when cold or hot.
  6. Re: Golf mK3, problems starting, not turning over till 3rd attempt or so
    Nova Scotia
    I believe that when you turn the switch forward to crank position, the cluster lights should go dim if the switch is sending power to the starter. If they don't then it's likely a switch/wiring problem.
    I know that's not a solution but it should rule out a couple of things.
    Here's a link to the switch issue I had. https://www.vwaudiforum.co.uk/forum/s...219#post543219
  1. Golf Mk3 Problems and answers...
    By Cragus in forum Golf MK3 - 1993 - 1999
    Last Post: 19-10-2009, 07:49 PM
  2. Please Help golf 1.6 mk3 sigma alarm problems
    By springy18 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-04-2009, 08:04 PM
  3. MK3 Golf GTI dash problems.
    By FROGEYEMAN in forum Golf MK3 - 1993 - 1999
    Last Post: 16-04-2008, 11:23 PM
  4. Golf mk3 starting problem
    By kan4u2 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2008, 12:43 AM
  5. Golf Mk3 Gti 8v Problems Accelerating
    By Mowgs in forum Golf MK3 - 1993 - 1999
    Last Post: 17-02-2007, 07:37 PM
