Thread: trouble code 18261?
  1. trouble code 18261?
    May 2010
    edinburgh
    hi have just done a code reading,got temp coolant sensor,and brake switch coming up,which i expected,also this one, which says:data bus powertrain implausible message from brake controller: would this be a follow on from the brake switch being faulty? and also got 00532,which says transmission control module relay supply voltage(B+)malfunction low battery or bad ground, had battery out a couple of days ago,could this have created this!!
    Help,as ever,greatly appreciated,adam
  2. Re: trouble code 18261?
    Norfolk
    All sorts of codes show up as present when the battery has been on and off. Clear the codes and see what comes back. They may not come back.
  3. Re: trouble code 18261?
    May 2010
    edinburgh
    hi martin,codes cleared and stayed away after re read, thanks again for your help,all your posts been very handy!! cheers adam
  1. Help please with problem on my A6 (flashing Glowplug light)
    By oDUTCHYo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-08-2010, 10:45 PM
  2. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  3. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
