Thread: golf mk5 no heater blower
Results 1 to 10 of 13
  1. golf mk5 no heater blower
    Aug 2010
    staffs
    hi i have a golf mk5 tdi - the heater blower does not work on any speed. i have changed the fascia contol unit, the resistor pack by the blower motor and still nothing. i have been told it could possibly be the climatronic control module - but i don`t know what or where it is located. many thanks
  2. Re: golf mk5 no heater blower
    131 Post(s)
    1974 Post(s)
    It may be a faulty blower. Cliamtronic is the full digital system (variable speed blower digital panel), I presume you have the basic Climatic (4 speed blower) system so you have already changed the control unit. Have you checked fuse 40 on the dash side panel fuse board?
  3. Re: golf mk5 no heater blower
    Aug 2010
    staffs
    yes its the basic 4 speed. i have checked the fuse and its fine.
  4. Re: golf mk5 no heater blower
    131 Post(s)
    1974 Post(s)
    In that case I would directly power the blower motor and see if it runs.
  5. Re: golf mk5 no heater blower - now sorted
    Aug 2010
    staffs
    hi all
    mk5 heater blower now sorted. problem was no fan speed at all:
    1) climatronic control panel changed - no change
    2) blower resistor pack changed - no change
    3) blower motor tested with direct battery feed and earth - working fine
    4) all wires in haynes manual led to item 3 onboard supply control unit J519 (located under drivers side lower dash panel)
    5) swapped this and everything was sorted - cost £40 from breakers ( main dealer price £252)
    hope this is of use
    Rog
  6. Re: golf mk5 no heater blower
    131 Post(s)
    1974 Post(s)
    That doesn’t add up if you look at the wiring diagram.
  7. Re: golf mk5 no heater blower
    Dec 2011
    langbank
    Hi there could you please confirm the part number of the unit as i have the same issues with my heater,cheers, jim.
  8. Re: golf mk5 no heater blower
    131 Post(s)
    1974 Post(s)
    I would need to know the vehicles details and which kit of HVAC system it has.
  9. Re: golf mk5 no heater blower
    Dec 2011
    langbank
    Hi there,thank you for your quick response, my car is the 2.0 gt sport on a 58 plate,and thats as far as i stretch as far as knolledge goes!!!!
    go past a fuse and a relay them i am goosed!!
    If you could please let me know where to look for the info you require i will do so in the daylight tomorrow.
    Again thank you for your help with this,
    Best wishes,
    Jim.
  10. Re: golf mk5 no heater blower
    131 Post(s)
    1974 Post(s)
    I will assume you have the manually regulated system (four individual blower speeds) made by Valeo (and right hand drive) so you need fan 1K2 819 015 C which is £126.85 inc. VAT from VW or £103.20 from GSF, their part number 932VG0400.
  1. What bugs you about the Golf Mk VI
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 22-11-2011, 10:08 PM
  2. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  3. Replies: 0
    Last Post: 03-07-2009, 07:48 PM
  4. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
