Thread: brake failure
  1. brake failure
    Jan 2010
    portsmouth
    Hi all,
    I have 2004 Octavia 1.9 tdi, it has had new brakes all round this year including cylinders (not master), however 3 times and several weeks apart without warning the brakes have failed. When i have gone to apply the pedal it has gone straight to the floor and only work if i pump it 2 or 3 times, i have been to two different mechanics and neither can find a fault! It has not lost any fluid and generally the brakes seem to work fine. On 2 of the occasions when they failed it felt also as if when i had stopped the hand brake had stuck on. and did not release until the car had been left for about 20 mins. Each time it has happened the journey has been less than thirty miles.
    Any advise will be a great help.
  2. Re: brake failure
    Nottingham
    what 'cylinders' were replaced (do you mean calipers?) and how was the system bled, the latter is particularly important.
  3. Re: brake failure
    134 Post(s)
    2022 Post(s)
    Is this a Mk1 or Mk2 Octavia? Can you find out which “cylinders” have been replaced?
  4. Re: brake failure
    Jan 2010
    portsmouth
    Quote Originally Posted by greg123 View Post
    Hello Greg,
    All i was told was that the front and rear shoes and pads had been replaced as well as the brake cylinders, i am not that mechanical minded so assumed what i was told was correct. I was also told the brakes were bled but not told how this was done. I keep s close eye on the fluid levels and they seem ok. It can go a month or more before it happens even to a point that i forget that it has happened before. It is frustrating though as i would like to sell the car but i cant do that until this gets sorted!
  5. Re: brake failure
    Jan 2010
    portsmouth
    Hello Crasher,
    Not sure whether it is a mk 1 or mk 11 it is the last of the classics on a 54 plate. I am waiting to hear which cylinders were replaced.
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. STOP! Brake Failure Message
    By SteveC in forum Passat - Archive Topics
    Last Post: 05-08-2007, 11:15 AM
