Thread: Additive to quieten noisy tappets
  1. Additive to quieten noisy tappets
    Aug 2008
    I have a Polo 1.4 8v. 1997 with 120k on the clock. The hydraulic tappets are quite "ticky", particularly when cold. Has anyone tried any oil additives made specifically for this problem ( Wynns, Forte etc). I've also been told that using an engine oil made for diesel engines can clean the gum from around the lifters & quieten things down. Any comments.
    Many thanks
  2. Re: Additive to quieten noisy tappets
    Mar 2008
    i used in the past the wynns hydraulic lifter stuff on my polo 6n 1998 had around 130k miles and it worked.
    the only thing that i can say don't keep it too long in the engine, when you change the oil make sure that you flush your engine
    chicco
  1. Audi A6 1.8T low oil pressure and noisy tappets
    By doctorc in forum New Member Introductions
    Last Post: 07-05-2009, 10:05 PM
  2. Tappets noisy - oil light flashes after cam belt swap
    By Anton Magus in forum Golf MK3 - 1993 - 1999
    Last Post: 20-05-2008, 02:30 AM
  3. GTI noisy tappets
    By motah33 in forum Golf MK2 - 1984 - 1992
    Last Post: 08-04-2008, 10:59 AM
  4. passat azm engine noisy tappets?
    By jaypassatestate in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 10:43 PM
  5. Hlep!!! or Noisy tappets on a 1.8 Avant
    By cherryuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-04-2007, 06:33 AM
