Thread: Binding Brakes
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Binding Brakes
    Apr 2010
    London
    Hello all
    Had this problem now for a little while, it's been intermittant
    and in fact it's getyting better as opposed to worse, but i know this is really
    a major problem waiting to happen.
    So i need to get it fixed ASAP.
    I was wondering though is it possible to buy a second hand servo and MC
    of course as long as they are in good condition.
    Can you tell is a second hand servo is in good clean condition?
    do you need to open it up?
    is there anything else to check out before going ahead and changing these two parts?
    maybe pipes or sensors?
  2. Re: Binding Brakes
    134 Post(s)
    2019 Post(s)
    A used servo is fine but not a used master cylinder. It is possible to see inside the servo with the M/C removed.
  3. Re: Binding Brakes
    Apr 2010
    London
    Hi Crasher
    I know you're a bit of a guru, so thanks for the really quick reply.
    Is it difficult to open and check or is the process quite easy?
    Is a MC from somewhere like euro parts or GSF ok?
    And lastly anything to check or try changing before i spend the big money on servo and MC?
  4. Re: Binding Brakes
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Are all the brakes binding or is it just the front or is it the rear ?
    Unless you give all the specific symptoms you will not get the help you need .
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Binding Brakes
    134 Post(s)
    2019 Post(s)
    Just remove the master cylinders two nuts and you can look inside for water damage. An MC from GSF is fine.
  6. Re: Binding Brakes
    Apr 2010
    London
    Hello thanks for that Crasher!
    It only seems to be the N/S/F brake/wheel that seems to be binding.
    its the only one where it feels noticeably hot.
    However previously it was the N/S/F and O/S/R that were getting hot.
    There is also a sort of squeeking type noise at very very low speeds or when coasting, that is also from N/S/F.
  7. Re: Binding Brakes
    134 Post(s)
    2019 Post(s)
    NSF binding is a classic indication of a seized servo.
  8. Re: Binding Brakes
    Apr 2010
    London
    I've had this issue on and off for a little while now.
    I started off being very bad and very noticeable, but it stopped for theb est part of a month and now has come back.
    But it's only very slight, i can notice it because i'm looking out for it, but when my wife or a mate has driven it they didnt realise anything was wrong.
    I would really expect this to get worse as opposed to only being slight.
    Price of a servo from Audi is £300 and £180 from europarts.
    cheapest i've seen is £90 for a used servo with 3 months warranty.
    In anyone's experience how are mechanics/garages in general with replacing with used parts sourced by the owner.
    Need a good place in Slough or Harrow to do the job.
  9. Re: Binding Brakes
    134 Post(s)
    2019 Post(s)
    How do restaurants feel about you taking in your own food for them to cook?
  10. Re: Binding Brakes
    Apr 2010
    London
    lol i see where you're coming from.
    but not like they make the parts.
    Anyway never taken my own food to a restaurant or my own parts to a mechanic, guess i won't be starting now either.
    Thanks for your help so far.
  1. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2010, 05:16 PM
  3. brakes stopped working coming upto the lights!
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 04-05-2009, 10:02 AM
  4. T4 brakes binding after bleeding
    By grumpydave in forum The Commercial Range
    Last Post: 22-11-2007, 12:23 AM
  5. binding brakes
    By dave downes in forum New Member Introductions
    Last Post: 23-08-2007, 12:43 PM
